Updated 2" Mopar Lift/Level Kit - Discussion
I tried running the ORP front springs and I do not know how the others do it. The handling on the truck was abysmal. Also, I tried to fit 35 x12's (wheel = 20 x 10 -24 mm offset) with that set up and they flat out wouldn't fit.
That said, on the Mopar lift without the ORP front springs I have a 2" rake and I hate it. It looks even more exaggerated with the lift.
Please let me know if you go the spacer route as I tried to put the Motofab 2.5's on and that was a no go as well. :(
I added a wulf 1.5" spacer and Rough Countrys forged UCA's for 3.5" lifts to my mopar 2". Ride is good. A lot smoother riding than it was with just the mopar lift for some reason. My tires were rubbing on the uca a bit, but I added wheel spacers which fixed that.
Hello everyone, just received my truck back from having the 2” Mopar lift installed with the “AC” part number. It’s a 19’ 6’-4” crew sport without ORP. I also had 33/12.50/22 Nitto Terra Grappler G2’s also installed at the same time by the dealership. I have read a lot about this kit from this thread and with most people’s dissatisfaction of the rake associated with the earlier models. I can confirm with the “AC” kit and without the ORP springs that it sits closer to level than what I have been seeing and hearing from other posts. The ride is very close to stock with taking heavier bumps smoother (tighter rebound than the stock configuration) with only a slight amount of additional road noise. I chose to go with the 33’s over 35’s for ride and fuel consumption in mind. I personally like the rake as I tend to tow or haul semi occasionally with plans of having air bags installed at a later date. First picture is the truck stock and second is at the dealership after install. The pictures on my driveway show more of a rake due to the slope of my driveway.
Great looking truck! I get mine installed this week, I can't wait!
How much are yawl getting the new AC (77072424AC) kits for ??? With Shipping I can't find anything cheaper than 1400-1500! I have seem folks in here find them shipped for around 1100-1200.
Thanks for the input, Looks good and im looking forward to doing about the same set up only with 34" same tire though.
cheers
got mine from the dealership i bought my truck for $1,300 ($1,287)
After reading the first few and last few pages, is there top strut spacers available, like the gm, but not the preload spacers? Looking to level an ORP. I know, probably been asked a hundred times in the middle of the thread...:)
Thanks for any info.
Anyone know if the MOPAR 2" lift is compatible with the Rebel? I don't see how it wouldn't be if people are taking ORP springs to achieve a more front to back level stance.
I believe the problem you'll run into is your Rebel spring perches will not fit on the Fox shocks in the front. If you pick up a set of standard spring perches then I think it will fit.
I was gonna get new ORP springs and top hat mount anyways so I didn't have to disassemble my factory Bilstein front coil-overs. So I'll add in those standard spring perches and see if it all works. Thanks for the reply!
Got the truck back and i couldnt be happier with it, thank you to everyone on here for the guidance and help.
mopar 2" lift (updated kit) happy with the rake offset , rough country .25 wheel spacers , and 295/60/20 ridge grapplers
So is the ab or ac the taller kit?
mopar 2" lift (updated kit) happy with the rake offset , rough country .25 wheel spacers , and 295/65/20 ridge grapplers
Just got mine done today. MOPAR 2 inch lift on an ORP with 285/65.
you have a 295/60 not 65
Wouldn't happen to have a part number for the lower spring seat would you? I'm having the hardest time finding it. Mopar parts websites don't even list it
Sorry, I looked too and no luck. Looks like they just show the shock as a whole assembly with the spring seat already on there.
2 inch mopar lift on top of 275 70 18 toyo open country at3s. Non orp. What do you think?
