Ultimate OBD JScan Thread
is there a way to set your turn signal to always on and retain the top brow (limited trim) to amber simultaneously? i seen tazer users can do this just wonder if jscan has that option figured out?
also is there a step i missed? i have my top accent light set to drl and amber but it only comes on if the truck is out of park.
I have the turn sig enabled for DRL and accents are still on. It stays on in park also. I don't have a limited so it may be different
25/26 you will need to use the Jeep ws option
thanks so much for that! I was able to get it to read the VIN, so it looks like it's connected correctly. What I was hoping to accomplish next was the steps to program a new keyfob as noted in a different post. However, i'm not able to do much and it doesn't look like i'm getting the screens and menus I need to be able to follow those steps. I have the vgate vlinker MC+ and the instructions on the jscan app say I need the vlinker MS. Do I really need that different version of vlinker? seems like it may be so, since the MC+ shows as "BLE" - bluetooth low energy, and the vlinker MS shows under a different section for OBD Link MX+ devices.
The 2025+ rams are a completely different vehicle as far as the communication architecture compared to pre-2025. You aren’t going to be able to do anything with JScan on your truck, even by faking it as a jeep WL or WS, which is read only anyway. Even with alfaobd on the 2025+, several tools and subscriptions are required to make any settings changes.
Even then, it’ll be almost impossible for the average person to program a fob on a 2025+, since all aftermarket tools now require NASTF credentials to do fob programming.
Not that it's going to resolve your issues trying to program a 25+, but the vLinker MC+ broadcasts both BLE(BT4.0) for apple devices, and BT(BT3.0) for Android. You need to use the "vlinker MC-Android" BT connection if you have an Android phone. If you have an Apple phone, you connect to the BLE device in the JScan app.
Does anyone know where in Jscan you can change halogen to led? It’s on a 2023 bighorn..Need to stop the flickering.
Any one know if JScan can do this ?
One of the comments said global up/down to enable this feature on ALFAobd .
Has anyone confirmed if this works? I tried searching but haven't seen anything. And if it has worked what is the sequence on the key fob?
Anyone know if I can use Jscan to tweak the sensitivity of the ambient light sensor for the headlights? My lights turn on when I pass under trees, which dims the dash.
Very annoying!
that sucks. Guess i'll have to turn off auto headlights, or is there any other hack?
Set the dimmer switch one click higher to have the dash lights bright during the day with headlights on. Then roll it back down one click when it actually gets dark out
I've been doing that as well. Appreciate the help.
