Ultimate OBD JScan Thread
Don’t know about that, but support at JScan is very helpful. I emailed them yesterday about turning on trailer light check and got a response from them this morning. Their support put me in the right direction and now trailer light check works.
So when are you going to post up that procedure?
Figured thread was dead or nobody interested since I didn’t get any response to my question, but here you go
In JScan,
Body -> Configure
Trailer Light Check Present
Change to Set
Trailer Light Check Cycles
Set to amount of times you want to cycle through lights.
In JScan,
Body -> Configure
Change to Set
It’s not dead. I think we have just done through the most common and useful changes already. Thanks for posting this. Very helpful! When does the check run or do you have to initiate it somehow?
In the trailer to section on dash display not on radio. After you set it up through JScan it will show up but give you some kind of error if you are not connected to trailer.
Ok cool. Thanks. I don't have a trailer section so guess I wouldn't be able to use it
Hi everybody.
I have a 2021 big horn 4x4 ecodiesel with the UConnect 3 8.4"
I have off road on closer but not on the radio.
Is it bossible to add it?
I don't have the "vehicle" app.
Hi everyone, I need some help. I have a new to me 2024 RAM 1500 Rebel Crew truck that came with the big tow mirrors with power, heat, turn signal, puddle, but they are manual fold. So, I am switching them out to the sport model mirrors with (supposedly power folding), heat, turn signal puddle, and blind spot.
Here is what I bought to replace the manual fold tow mirrors with power folding sport mirrors:
Left mirror - 68610315AA which is supposedly power folding, heated, turn signal, puddle, memory.
Right, mirror - 68610314AA which is supposedly power folding, heated, turn signal, puddle, memory.
Drivers door window switch with power fold button - 68590582AA
Drivers door module - 68517697AB
Passenger door module - 68517696AB
I also bought Bluetooth OBD Link MX+ with bypass cable and used Jscan to inable the powered mirror activate functions. The new mirrors and door switch are installed, and the door modules were already installed in the truck from the factory. I have installed the mirrors and door switch, all the mirror functions appear to be working like they should, accept I cannot get the power folding sport mirrors to power fold?
As best I cannot tell, these are both power folding mirrors, the door modules are supposed to support power folding, and the door switch is supposed to be the right one for my truck. All the parts are new oem parts. Could maybe someone with better knowledge, or resources than me, please check my numbers and confirm I have the right parts? Is there something I am missing, or not thought of? Maybe the door switch is bad? Any help is very much appreciated.
Same as AlfaODB. You need an ODB reader and a bypass cable.
THIS is the cable I used and I believe THIS is the reader I used. You also have to buy a license for your particular VIN.
So I just added new tires for my 2020 BTS 1500. Went from 275-55 20 to 275-65 20.
So I want to change computer tire size.
Just downloaded the JScan app and will order this reader noted above.
Veepeak OBDCheck BLE+ Bluetooth OBD II Scanner Wireless Car Diagnostic Scan Tool​
Why do I need the cable? Isn’t the VeePeak Bluetooth to the JScan phone app?
Good thread! Lots of info to read back through.
I have had AlfaOBD almost since I bought my Ram in 2019. Have used it for lots of stuff. I have only used JScan for a little over a year, since I bought my JK Wrangler. I actually made my first programming change (tire size) to the Wrangler using AlfaOBD, but I have found JScan to be more user-friendly, with its layout and menus, even for my Ram. I suspect that this is just a matter of personal preference, but I have also been reading that JScan is a bit more "capable", for some things - like pairing key fobs.
The cable is to bypass the SGW so you can make changes to the BCM
Haven't driven the truck, but took it for alignment (original rt front outside was worn badly and cupping with 60k miles) and PA state inspection.
Shop asked if the battery was disconnected in the last 2 months? No. Stated the emissions readiness codes are not ready and will not be reset until driven. Couldn't perform emiisions test.
Odd since I checked codes with Jscan and none existed? So I didn't clear anything. All I did was revise tire diameter to 34".
Anyone have any issues like this after using the Jscan?
Hello, Has anyone ever tried to disable the Active Grill Shutters using Jscan so they can be lets say zip tied into the open position for max airflow over the radiator. I know on mine it gives me the ability to see that it says the truck is equipped with the system, but I am nervous to see if the system can be disabled and made not equipped so the CEL wouldn't come on. I am assuming the air dam would need to be disabled as well as they seem to go hand & hand
I removed the entire active grill shutter and the front air damn a few years ago. Never had any issues.
is there a way to set your turn signal to always on and retain the top brow (limited trim) to amber simultaneously? i seen tazer users can do this just wonder if jscan has that option figured out?
also is there a step i missed? i have my top accent light set to drl and amber but it only comes on if the truck is out of park.
I haven’t read all 21 pages of threads yet but has anyone on here changed their tire size in jscan have to do anything with the TCM? Will calibrating the speedometer change the shift points automatically or is there another setting in the app you have to run? Went from 275/55R20 to 285/60R20 with 3.21 GR. Thanks in advance
Hello all. I promised I tried keyword searching a few different things to find it, but my question is this. I have Jscan with the vGate LE adapter that is listed by Jscan as compatible. It connectes and tries to run, but is not able to fetch the VIN. Is that an adapter issue, or something else? I have a 2025 Ram 1500 Bighorn, and the option available in jscan is the Ram DT but lists 2019-2024 (iirc). Does that mean that 2024 and 2025 are not supported at all, or just labeling thing in the software? thanks!
25/26 you will need to use the Jeep ws option
All you should need to do is follow the procedure here Ultimate OBD JScan Thread.
The trans module should relearn and adjust accordingly. I fine tuned the tire size with a couple of GPS speed apps.
