A blinker is without a doubt a safety issue. It is legally required to be manufactured with the vehicle and used while driving. The incorrect use or lack of using a blinker can and does cause accidents, this includes a malfunctioning blinker.Cbty25 or something, I can't remeber his exact user name, is a mechanic, and said they had a run of defective parts for a few months from the supplier. Very common complaint right now. Not something they will recall, because it's not a true safety item, but they will fix under warranty.
Post #39 should really help you out on the subject.A blinker is without a doubt a safety issue. It is legally required to be manufactured with the vehicle and used while driving. The incorrect use or lack of using a blinker can and does cause accidents, this includes a malfunctioning blinker.
I see I shorted you a couple numbers.Post #39 should really help you out on the subject.
The blinkers work, they just don't shut off. That's nothing they will recall for, but it is warrantied.Post #39 should really help you out on the subject.
I appreciate you posting the recall & I'm sure it will help out plenty of people.Post #39 should really help you out on the subject.
If you leave the stalk in the high beam position it works all the time.
I had mine replaced and now its making this plastic scraping sound when I use the turn signal. They are telling me that they replaced it with another one and it still makes the sound. Their excuse is that ram changed the part and now it makes that noise. Is yours doing this or is it still quiet and smoothI had mine replaced yesterday after being on backorder for several weeks. The replacement switch is part # 68545657AC and it works properly.
Don’t see 2021 on the recall and mine has been doing this for somePost #39 should really help you out on the subject.
Mine is smooth and actually cancels on left turns. Although I like the auto high beam feature so I tend to push the stalk forward into that mode.I had mine replaced and now its making this plastic scraping sound when I use the turn signal. They are telling me that they replaced it with another one and it still makes the sound. Their excuse is that ram changed the part and now it makes that noise. Is yours doing this or is it still quiet and smooth
Is there a recall? Last I saw, it was only a TSB.Except that was a large part of the reason for the safety recall previously linked. Part of the reasoning listed for the safety recall was "A turn signal which remains active after a completed turn may cause surrounding drivers to misunderstand the intent to change vehicle direction."
There is a recall, but not for DT trucks. Classics, and Heavy Duties, per post #39.I think it's a TSB for 2023 models.
Add 2024’s to the list. My 24 with about 6k miles has started not canceling left hand turn signals now within the last couple of weeks.
