This guy claims to have been on five Presidential details as the local LEO attachment.
					x.com
Due to X’s post constraints of no more then 280 characters I’ve consolidated his 21 post into one to make it easier to read and to forward to your like minded friends.
(2)
1. The Secret Service employ a  multi-tiered defense in depth approach to protective missions. An inner tier offer close protection support, these being the agents you see rushing in and surrounding Trump after the initial shots go off.
(3)
A second middle tier is tasked with identifying and defending against mid-range threats, i.g. the crowd, etc. This tier is largely comprised of local and state law enforcement temporarily attached to the security detail. This is the area that I worked on prior details.
(4)
Finally, you have an extend tier, which covers long distance threats. This can include counter sniper details and cyber/SIGINT support and CBRN defense.
(5)
2. People have wondered how could the counter snipers in the videos not have seen the would be assassin prior to him getting off a shot.
This is because the area of responsibility for those counter snipers on the roof behind Trump was very likely in the extend tier
(6)
Essentially they were scanning for threats a great distances well beyond the roughly 150 meters the threat appeared.
This is evidenced by the fact that the elevated counter sniper has to dramatically drop his line of sight to respond to the shooter.
(7)
Secret Service advanced teams would have absolutely pre-scouted the location and identified the building the shooter used as a vulnerable spot in the defense.
Which begs the question, how was this guy still able to climb on the roof and get off a shot?
(8)
Based on limited details at this point, IMO, the security breakdown occurred in the middle tier, which would likely include law enforcement who were supposed to be assigned to the area near the outbuildings.
(9)
How that significant of a breakdown could occur is up for speculation. However, like I said this tier is largely dependent on local law enforcement and not the Secret Service. So speculatively, the local LEOs who were supposed to be in the area and make sure no one with a
(10)
gun climbed up on the roof, f*cked up.
3. People have said that witnesses saw the guy with the gun on the roof, told police, but that they failed to respond and prevent the assassination attempt.
So how does that happen?
(11)
Well, there’s typically limited lines communication between the Secret Service and the local LEOs working the middle tier.
You usually have one or two local LEO liaisons who have direct communication with the Secret Service, which means communications on the ground
(12)
between the local LEOs being told about the shooter are being routed through dispatch, to local liaisons, then to Secret Service.
Compounding the difficulty to rapidly respond is the fact that there’s always some confusion and inefficiency when multiple different LEO
(13)
agencies come together to work a detail. Most of these agencies aren’t used to working with each other and aren’t given much information beyond a few pre-event briefings.
(14)
I actually saw what can go wrong in these scenarios first-hand when President Bush’s Secret Service detail almost engaged a local police SWAT/counter sniper team during the 2004 G8 summit. No one had properly communicated the local SWAT team’s position so all the
(15)
Secret Service saw was heavily armed individuals with a line of sight on the President.
The whole thing was seconds away from being a tragic incident.
In this same vein, there was likely some delay and confusion with the initial reports of a person with a gun on the roof
(16)
as local cops and Secret Service agents would all be trying to confirm the shooter didn’t belong to one of the security support teams.
(17)
So in summary, when looking for blame in this massive security failure, if I was a betting man, I’d say the answer rests with whatever detail (likely local LEOs) were assigned to the area near the outbuildings.
(18)
I’ll also add that I worked 5 Presidential details as a local LEO attachment. Even though I was in close proximity for each detail, in only 2 of them did I actually ever see the President or Vice President. That was Bush, while he was in the limo driving away. And Chaney
(19)
but that was because I was on an inner position, feet away from him.
You’re explicitly trained that your eyes are always on the crowd, surroundings and potential threats.
Never on the President themselves.
For obvious reasons…
(20)
Now my experience is entirely limited to official presidential visits, which are planned at least months and in some cases a year in advance.
It’s likely that some of the breakdowns or issues I mentioned can be exponentially increased when it comes to campaign trips
21)
as these stops can come up or change on very short notice.
