So after I cleaned the throttle body to address the random drops into neutral, I installed an oil catch can on mine, assuming it must be blow by that made the throttle body dirty. In the past year when I have checked the can, it has been dry and clean. I don't know why my throttle body was dirty. Smarter minds on here might know?Whelp thanks to those who recommended the throttle body cleaning. So far I haven’t be able to duplicate under same driving conditions. I ended up using throttle body cleaner to remove the gunk around the opening and flap. I tried doing it with the tb on the truck and it wasn’t going to well so I took the damn think off cleaned it. I have 66k on the truck and it took a good deal of cleaning. I assume it’s blow by getting on there I wonder if guys that are running catch can are experiencing this? Thanks again for those who shared there thoughts!
Was your can installed properly? Here's mine after 3,000 Miles, almost half full.So after I cleaned the throttle body to address the random drops into neutral, I installed an oil catch can on mine, assuming it must be blow by that made the throttle body dirty. In the past year when I have checked the can, it has been dry and clean. I don't know why my throttle body was dirty. Smarter minds on here might know?
I believe I installed it properly, unless the inlet and outlet are mislabeled on the can? Or is the sintered filter not allowing flow through it?Was your can installed properly? Here's mine after 3,000 Miles, almost half full.View attachment 180055
Welcome aboard. Tell us about your truck, year, miles.I have also experienced the same issue twice. I have only had the truck for 2 months! Joined here to find a resolution to the issue. Seached for TSB's and or recalls. Nothing yet.
Thanks Attaboy! I'll have to check that also. I don't know if it's software determining to throw the transmission into neutral based on voltage or RPM, but if it's voltage, it sounds like a different model alternator, one capable of putting out more voltage at lower rpm might be a workaround as well?Cleaning my throttle body (TB) made a difference but when I was cleaning it, I noticed the clamp was pretty loose on the TB which made mine act like it had a vacuum leak. That presents many of the same symptoms especially if it throws your idle off. It can cause low voltage when the engine is stalls or stutters from the vacuum leak. This is more pronounced when starting a cold engine because of high idle for the first 30-60 seconds. Hope this helps. Also, check/replace your air filters.
Let us know if you figure out the software aspect of this effed up drop into neutral.Thanks Attaboy! I'll have to check that also. I don't know if it's software determining to throw the transmission into neutral based on voltage or RPM, but if it's voltage, it sounds like a different model alternator, one capable of putting out more voltage at lower rpm might be a workaround as well?
You're right, Vulpes! That doesn't look that dirty at all. My throttle body wasn't bad either. There was a little bit of a build up but only on the ID of the throttle body and the back of the butterfly. I had a GMC Yukon years ago that was so built up that it would idle at around 450rpm.Let us know if you figure out the software aspect of this effed up drop into neutral.
For my 2019 Rebel, which was dropping into neutral a few times a week, I cleaned my TB on August 4, 2022, and it has not dropped into neutral since the cleaning. That's almost two years without this d*mb factory option.
IMO, it wasn't even that dirty.
When I took mine apart, I looked for hours, but could not figure out how to change the jets.
Hello anthonya2006,Been following this thread for a while, I have a 2017 rebel ram 1500 same issue, will be driving along and it just kills the acceleration and says shift to P. Have to turn the engine completely off and on again then it runs fine till it happens again, no error code. Cleaned the throttle body and it continued to happen. I had a mechanic look at the engine seems nothings wrong so assuming it has to be technical somehow. Bringing it in to the dodge ram dealership directly this week so any guidance to give them would be great so they don’t just come back with “we couldn’t recreate the issue”. I’ve had it happen like 5+ times on a drive home and it’s dangerous
Thanks, the dealership was finally able to figure it out. I had a pulsar after market tuner and that plus some PCM issues was causing the throttle body to not always open. So they removed the tuner and reset the PCM to factory and since then absolutely smooth riding!Hello anthonya2006,
That stinks. I hope the dealer was at least able to impart some wisdom if not just fix the darned thing. I've run mine several times after cleaning the throttle body and adding chevron to the tank. I'm almost half way through the tank (I work from home so I don't do much travelling) and haven't been able to reproduce it. Maybe tomorrow morning I'll go back to the intersection it happened at last time. Hard braking was mentioned in some of the other peoples' scenarios, so maybe I'll do more of that during testing. No combination seems to make it happen.
I also have to plug in my OBD2 magic box and see if anything is in historic. I might also put it into live data record when approaching that intersection. As soon as I do I'll report back here.
