Transmission falling out of Drive on downshift, blinking, displaying "shift to P" and back
Wanted to give everyone here an update. I have cleaned my throttle body + reset procedure a total of 3 times, each time it buys me about 2-3 days where the "Shift to P" error will not happen. So my next logical step is to replace the throttle body. I've ordered that part and it should be here Wednesday. Going to put the new TB in, perform the reset procedure again, and run some Techron through.
The last time I cleaned it / posted about it, @RamCares reached out. I explained I had taken the truck to the dealer 3 times for this issue and each time they could not replicate. My truck is now out of warranty, and I explained that if I take it a 4th time then it should not be on my dime (since they failed to fix it the prior 3 times). Long story short, she said I would have to pay to have them look at it again. So, not exactly the customer service I was hoping for. This error code is going to get someone killed trying to cross a busy highway or railroad.
that's BS. this should be a recall.
Hello neutral drop support group. Well my neutral drop is back. I cleaned the throttle body back on August 4, 2022, and it stopped dropping the truck into neutral while driving. The neutral drop while driving returned today October 10, 2024. This time I was in accelerating traffic on a freeway on-ramp and vehicles swerved around me. Will pull the throttle body when I get a minute and report back. Also reported this to NHTSB.
Happy new year neutral drop support group! Here's an update. Had two years of no drops into neutral after cleaning the TB. Then in October of 2024, it did it once, and then cleaned the TB again right after that incident. It is now January 13, 2025, and it has not dropped into neutral since then. So I dunno...
TRUCK 2019 RAM LARIME 4x2
Same thing dropping into nutrual while coming to a stop. I took to local dealer Daphne AL and they checked the camshafts, that wasnt any issue. They contacted chysler with no remidy. I havent cleaned the TB yet or added the Tecron fuel treatment. I will do this asap and report my findings I to have made a claim with NHTA
I have been having this issue for 2 years. Happens more then 4 times a month and sometimes daily when the weather is cold.
Same on my ram,2019 it's been doing this since 2022 and around 60k, now at 82k it started doing this After I swapped my battery in 22. Couldve reset prior software with the actual issue
I’ve had this issue for a while. Brought the truck to the dealership, they flashed everything and it seemed to be fine for a few days. Issue came back and feel like it’s worse now. Truck is back at dealership, I opened a case with RamCares, they reached out to the dealership today to have an open line of communication and to potentially get a master mechanic on it. After reading the threads feel like this isn’t a solvable issue. Thinking about selling my baby 2019 Rebel only 40k miles. This is ********.​
Capriciously dropping into neutral is terrible option for a vehicle that no one would place on an order sheet. :p
I've had success with disconnecting the battery and then removing the throttle body and giving it a thorough cleaning, as suggested by others here.
Some of us have also reported this condition to the National Highway Transportation Safety Board (NHTSB). Link here: Report a Safety Problem | NHTSA
Lol right?! After reading through the threads, I will ask the dealership to pull off the TB and clean it if they don't have any other solution or don't get a solution from Stellantis. I'll report back in this thread with whatever solution they come back to me with, or if they end up cleaning the TB for me. Thanks @Vulpes
Quick update, I got my truck back a few weeks ago from the dealership, after being there over 30 days. They said what was causing the issue was a tracker that was installed from the dealership that I purchased the truck brand new from. I knew it wasn't an actual fix, but they just did that to give the truck back to me. Also, super sketchy that the dealership I purchased from but an off brand tracker on it and I didn't even know. Anyways, this same transmission issue happened to me at the end of last week, surprise. I just dropped the truck back off at the dealership this morning, spoke with my Stellantis rep about starting the process of a buy back or getting financial compensation.
Happened to me again, the thread originator. I’ve noticed a number of other times recently that the RPMs dropped to near 0 and the engine nearly stalled. When I go in to the dealership for my ABS recall and next oil change, it would be a good time to clean the throttle body. If @RamCares , FCA will pay for it.
Actually I was in a good place to kick off a class action lawsuit and I’m sorry I didn’t take advantage guys. I’m working remote now so not using the truck much. I was turning into a grocery store parking lot. Looking back, I should have run the nearby pedestrian crossing sign over. I could sue for lack of control of the vehicle due to this issue of which the manufacturer is well aware and unwilling to address.
Hey all,
I'm having an issue in which my 2019 Ram 1500 Crew Cab 4x2 Laramie 5.7L V8 with 8 speed auto with 3.92 rear axle ratio and am hoping you can help. Upon braking and downshifting and perhaps more when vehicle is "cold", transmission occasionally falls out of drive without user input. The D indicator around the shift knob and in the instrument panel will blink. Tried to capture the blinking in the images below. In this case, the vehicle is parked more or less at a traffic light, but it has happened enough that I have scrambled and captured videos at 7 MPH as well. The instrument panel will also display the message "Shift to P then Desired Gear". In this time, the engine remains running and the transmission enters a neutral stage. This can be pretty dangerous when it occurs upon braking for a railroad crossing or yield and merge situation in which I cannot accelerate into traffic or away from a train. The transmission can be re-engaged by shifting to P then back to D. I do have 57,000 miles on the vehicle and this would definitely qualify as a powertrain issue, within warranty. I have taken the vehicle into the dealership with a description of the issue and a video. The shift knob was replaced to attempt to resolve with no change in issue frequency. I'll be taking it back this week for the last time. Is there a transmission programming change required for the rear axle ratio change that perhaps didn't happen? I bought the vehicle used and don't do much towing myself. I may prefer to swap the rear end for original 3.21 if required to resolve. Is anyone experiencing a similar issue? Any ideas to resolve? Please help
View attachment 77802View attachment 77804
View attachment 77803View attachment 77805
I’m having the same issue
I cleaned only the throttle body. But now that I think about it, around the same time I also had the battery disconnected for some other work, not sure if that also affected it? Maybe a "reboot" of the computer?
Did you have both terminals disconnected?
I have a 2019 Ram 1500 Limited all gas, 195k miles and this happened to me about a month ago while on the expressway during rush hour. All i remember is turning shifter left and then back to D and everything was fine. I have been having issues with my truck unrelated to this issue but in the process did a cursory clean of the TB....im going to do a thorough clean of the TB and add Techron with the hopes that this will not happen again. And maybe it may fix my P0175 issue... 🙏 Im a novice Youtube mechanic so im learning and I appreciate everyones input here. I will post pics of my TB. Stay safe Ram family.
has anyone tried cleaning the shift knob as in pull it out and blow out the electronics??? sounds crazy i know but i seem to remember seeing something about that. i didn't read 33 pages of posts but cleaning the TB seems like pising in the wind.
a physical connection such as a cable was pretty bullet proof. why did they take that away????
the rotary shifter may be the biggest thing i hate about my ram. i freaking HATE it!!
Well boys, this issue happened again to me today. After going a few months without it happening it’s back. And it’s happened 3 times in the past two days. Called @RamCares Customer Support, they said they can’t reopen the case unless I take it back to the dealership. My local dealership doesn’t want to take the truck back in unless there’s a check engine light showing or unless it happens and I bring it straight in. I work 30 min away and is usually happens when I go to get lunch or on my way home. So really hard to do that. This issue is so aggravating, my truck has already spent 45+ days in the shop this year at the dealer and no resolve. Thinking I’m just going to sell it and buy a used raptor. This is fkn annoying. @RamCares would it be easier for me to find a lemon law attorney and file suit?
