Ruben-Ram5th 1500
- Apr 11, 2021
I currently have my 19 Ram 1500 4x2 crew cab in the dealer for the 2nd time with the exact same issue. I believe this started at the 35k miles. The service advisor at the dealer told me is that this is covered under Chrysler powertrain warranty and that there are 3 steps:Hey all,
I'm having an issue in which my 2019 Ram 1500 Crew Cab 4x2 Laramie 5.7L V8 with 8 speed auto with 3.92 rear axle ratio and am hoping you can help. Upon braking and downshifting and perhaps more when vehicle is "cold", transmission occasionally falls out of drive without user input. The D indicator around the shift knob and in the instrument panel will blink. Tried to capture the blinking in the images below. In this case, the vehicle is parked more or less at a traffic light, but it has happened enough that I have scrambled and captured videos at 7 MPH as well. The instrument panel will also display the message "Shift to P then Desired Gear". In this time, the engine remains running and the transmission enters a neutral stage. This can be pretty dangerous when it occurs upon braking for a railroad crossing or yield and merge situation in which I cannot accelerate into traffic or away from a train. The transmission can be re-engaged by shifting to P then back to D. I do have 57,000 miles on the vehicle and this would definitely qualify as a powertrain issue, within warranty. I have taken the vehicle into the dealership with a description of the issue and a video. The shift knob was replaced to attempt to resolve with no change in issue frequency. I'll be taking it back this week for the last time. Is there a transmission programming change required for the rear axle ratio change that perhaps didn't happen? I bought the vehicle used and don't do much towing myself. I may prefer to swap the rear end for original 3.21 if required to resolve. Is anyone experiencing a similar issue? Any ideas to resolve? Please help
View attachment 77802View attachment 77804
View attachment 77803View attachment 77805
Step 1) do a relearn on the tcm and test drive it for 1k miles (Did a temporary fix until 688 miles and then issue return).
Step 2) replace the tranny valve body ( that’s where I am right now) and test drive for 1k miles
Step 3) replace the transmission.
Oh! This has also develop an annoying play on my driveshaft. Feels like you are pulling a trailer and there’s a lot play on the hitch. Also, I notice that there’s no need to go all the way to parking when the message pops up. You can go to “N” neutral and the “D” and it will also clear the code.
