No, that ball is in your court. I supported my opinion with the reason and logic below and you supported your opinion with absolutely nothing.
As I've said several times now the difference may be so small as to be insignificant, but duct work sitting on top of the radiator will collect more radiant heat than ductwork below or along the side of the radiator. As a result the air traveling through the warmer duct work will extract and retain more heat than the air traveling through the slightly cooler duct work. The speed of the air will just reduce the heat transfer; not eliminate it.
If you fail to understand or believe what I've written above then I can't help you. I have no desire to give you more of an education or scientific proof of the physics of heat transfer.
