Thoughts on Cold Air Intakes?
Cooler air or less filter restriction can allow the engine to pass more air, and thereby make more power, but it's a small amount and only at or near wide open throttle. Most of the time you will be deliberately restricting airflow with a big ol' throttle plate anyway, and they will make zero difference under those conditions.
That's the point.
What does 105 mpg have to do with an air intake?
I have gone faster than 105 even when I had my stock intake, maximum speed has nothing to do with this conversation.
I never mentioned mpg. Ram puts a speed limiter on the 1500's. 105 MPH. I don't know about the HD's. But it only needs to take in enough air to get to the limiter and the stock intake does this.
mpg was a typo I was quoting your 105 mph.
105 mph has nothing to do with stock or aftermarket airboxes.
I think he means it’s not a race car where ram air would help at really speeds
Thanks. But what it means is, there is a limiter and there fore the computer only allows for enough airflow for that much Rev. So the stock intake can handle that quite well
Yes, this is true. Cooler air is more dense than warm air. But the factory intake is a CAI, and already brings in cooler air from outside the engine bay. No aftermarket CAI will bring in cooler air than what the factory intake does.
The limiter has nothing to do with airflow, or PCM only allowing a certain amount. The PCM doesn't control throttle blades/airflow to control the speed limiter. It's a fuel cut off. At WOT, you will have more air being sucked into the engine at higher RPMs, and lower speeds, before the shifts, than at the speed limiter.
Yup. True story
Well, the best way to put this to rest would be from an "air density" standpoint. When an intake valve opens and piston strokes down it pulls a vacuum through the intake etc so in theory there should be some measurable amount of vacuum between the filter and intake manifold. If someone installed a vacuum gauge between filter box and intake on oem system than on CAI system and measured results at a couple of rpm ranges the results would be irrefutable. The greater the vacuum state of air the less air there is, so if readings are the same it does nothing but if they are different one could use Boyle's gas laws to calculate the air volume difference. Would also be nice if the gauge had a max memory to it, air is elastic so you could have a situation where a CAI makes no difference at stable rpm but maybe while increasing it does.
Though the fact that CAI manufactures aren't measuring and advertising this important measurement leaves me doubtful that theres any difference, still may buy the oem one though:)
