silver billet
- Apr 18, 2019
I disagree about the disagreement.
Some people just disagree because they're disagreeable people
That's a lot of work, and a lot of butchery to jousing and harnesses. No thank you. And it only replaces the drivers, if the LED itself is bad, you still have to replace it.![]()
ORACLE Lighting 2019-2024 Ram 1500 RGBW+A Headlight DRL Upgrade Kit - LED Projector Headlights
Product Description Features What's Included Installation Part Numbers Introducing the Ram ColorSHIFT® RGBW+A Headlight DRL Upgrade from ORACLE Lighting. This product is designed to fit Ram Models with the Factory LED DRL Option and Projector Headlights. Featuring our new high-performance RGB+W...www.oraclelights.com
The LEDs are replaced too. The factory LEDs are White and Amber, the replacement LEDs are RGB + White and Amber.That's a lot of work, and a lot of butchery to jousing and harnesses. No thank you. And it only replaces the drivers, if the LED itself is bad, you still have to replace it.
Also if it's already broken.... Not much to lose.The LEDs are replaced too. The factory LEDs are White and Amber, the replacement LEDs are RGB + White and Amber.
Cheers
That sucks.Well this didn’t do anything.
“They exhausted all avenues” and cannot offer to cover the repair
This is also why I decided against the extended warranty. I've been burnt too many times when something goes wrong there always seems to be fine print that says this and that isn't covered.Was considering getting MaxCare and this sealed the deal for me. Most concerned about electronics going bad vs. mechanical parts. If it won't even cover headlights (it's not like they're bulbs), then what good is it?
