These headlights are crazy expensive
IvoryHemi
Both my upper and lower DRL’s burned out on the driver side headlight assembly.
Ram rejected my MaxCare coverage and dealer wants $1,900
Damn.
Cbty2050
Call maxcare or have the dealer call and explain the failure. We have had luck getting lamps covered by actually calling and talking to them.
mike_ct
how about get a tazer-dt and change the options to "amber drl" and just leave the white led strips burn out?
djevox
VP of Creative Thinking
MD
I could be wrong, but I think the bottom strip is the same one that can glow amber.
There are used headlights on ebay and aftermarket that are significantly cheaper if you don’t get it covered and have the ability to do it yourself. I love leds, but hate them at the same time because of situations like yours.
Jimmy07
Honorary Site Supporter
Even brand new, it is significantly cheaper:
silver billet
Just grab a pair of Morimotos or Vland. The Vland especially are pretty cheap, about $600 for a pair IIRC, and they and the morimotos look better than stock LEDs too.
SKT Customs
5thGenRams Vendor
5thGenRams Vendor
San Diego
That price is ridiculous and that’s bull crap the dealership denied the warranty! What good is a warranty if it doesn’t cover expensive failures like that?! Most LEDs are rated to go at least 50k hours. I bet you’re only at like 2k hours max!
djevox
MD
I should point out that the price is most likely with labor.
Cbty2050
The dealership did not deny the warranty. Maxcare coverage states not covered. It's all processed by a labor op code.
Idahoktm
North Idaho
I disagree. The stock Limited headlights look much better than any aftermarket headlights. I don't think you can use those on a Limited anyway, unless you swapped out the entire front end of a Laramie/Big Horn.
swing4terps
Harford Cty, MD
Was considering getting MaxCare and this sealed the deal for me. Most concerned about electronics going bad vs. mechanical parts. If it won't even cover headlights (it's not like they're bulbs), then what good is it?
silver billet
The limited lights are great, I missed the fact that his is a limited, saw "laramie" in his sig and assumed he was running standard LEDs which IMHO are quite poor. Morimoto replacements for the standard 1500's are stunning, both the cheaper hybrids and the more upscale version too.
Idahoktm
North Idaho
I disagree with that too. The Laramie headlights aren't as good as the lights on the Limited, but they're pretty good. The two aftermarket headlights you listed are much better looking than the Big Horn halogens, but the OEM Mopar LED's are much better looking...especially the Night Edition version.
davidajpritchard
This is where the warranties have not kept up with the technology. In their warranty documentation they would just consider the led's to be normal lights and they are far from it!
Sent from my SM-S908W using Tapatalk
silver billet
You're quite welcome to disagree.
Darksteel165
Massachusetts
Exactly, Light bulbs are considered wear and tear like brake pads. LEDs should not break, and when they do break it's not the LED breaking. It's some random part on the board.
I had to replace a $0.02 diode on a thrid break light strip before on my 2012 Camaro because the dealership said it was $850 to replace the third break light (led strip) that went out
I don't think warranties are going up update as the manufacture wants to screw you over and make more money by giving your a defective product. Most LEDs should last 20 years on average and generally even longer.
ProjectsInMotion
