Shives
All updates I’ve tried so far, turn camera. Neat feature. Always mutes the radio…
Anyone else? Has this been asked. Sorry
260$ ThanksPrice?
Mine does it off and on and sometimes when on SXM it put the song back 10s if you turn left sometimes it will FF 10sec turning right? No issues with BT or CarPlay. If it gets worse I will turn it off but I like to keep rear cam on when towing. I don’t think there’s a separate seating to just e able to keep rear cam on.All updates I’ve tried so far, turn camera. Neat feature. Always mutes the radio…
I've never understood why you would want the rear camera to come on when turning.All updates I’ve tried so far, turn camera. Neat feature. Always mutes the radio…
Not sure what towing a trailer has to do with it.Tow a trailer.
Turn on backup camera to see trailer when towing..... I use mine with the air suspension to backup to the trailer ball and snatch it without even getting out of the truck. Once under the hitch I can raise the truck, then get out, lock the receiver and throw on the chains and lights. No guessing if you are lined up at all.Not sure what towing a trailer has to do with it.
Yeah, but it turns in when you back up anyways. Why only when turning? What does turning have to do with needing to have back up camera on?Turn on backup camera to see trailer when towing..... I use mine with the air suspension to backup to the trailer ball and snatch it without even getting out of the truck. Once under the hitch I can raise the truck, then get out, lock the receiver and throw on the chains and lights. No guessing if you are lined up at all.
It just enables or disabled the panic button function in the keyfob. I've had my panic alarm for off a few times by accidentslly hitting the button of fob.Question and can’t find anything related to this but in the Tazer dt setting panic set don’t know if I touched something but mine was off I was messing with the option before which is the splash screens don’t know if I might have pressed it. But what is panic suppose to be on or off any help would be appreciated
Yes, it should be enabled from factory.So it should’ve been on from factory on Tazer?
It functions as a blind spot monitor for lane changes. Other vehicles have this as an option from factory.Yeah, but it turns in when you back up anyways. Why only when turning? What does turning have to do with needing to have back up camera on?
I've been doing it all wrong using my mirrors?It functions as a blind spot monitor for lane changes. Other vehicles have this as an option from factory.
Yes, you can sell it if it's unmarried. Did you reset your tire size back to stock before removing? Simply unmarrying will not do that.Just went back to stock tires. I un-married my Tazer Dt. Worked great no issues. Since it is now un-married I can sell it correct?
Yes I did. Thanks for the heads up.Yes, you can sell it if it's unmarried. Did you reset your tire size back to stock before removing? Simply unmarrying will not do that.
Is there any way to turn on ONLY the turn signals as DRL? I’ve set the turns as DRL, but my white factory LED DRL remain on as well. I can’t seem to find a setting that uses only the turns.
Also, can anyone explain what “Disable Halos” does? I’m not even sure if I have these on my 2020 Laramie...
EDIT for anyone one else as stupid as me
The marker lights option on the lights knob starts the white lights as well as DRL, so you need to be on the AUTO setting during the day to get the turn signals only to activate as DRL. No wonder I couldn’t get it at night!
