Jordan2929
No, so the screens can be updated over the air doesn't matter if its the small or big screen. The amp has to be updated at the dealership.So the 8.4 is not done over air like the 12 inch?
Exactly what I tried telling them, they had absolutely no interest in helping me out. Unfortunate considering I spent 57,000 on a truck from them.It doesn’t sound great at al without update, if so why an update after 3 month you release a vehicle?
AgreeI will say it is improved after the amp update but definitely not superb. Again sound is subjective to everyone’s personal preference but it seems like the bass is being reproduced at higher frequencies then it should be. Not sure if it is the way the system is tuned or the frequency range of the speakers. It is missing a full balanced sound especially at the lower frequencies.
That is shame for sure! They need to assist you ans solve some issues.Exactly what I tried telling them, they had absolutely no interest in helping me out. Unfortunate considering I spent 57,000 on a truck from them.
Thanks, I realize the same.So, after a few weeks of ownership and listening to the HK system, I have some observations.
1. The system is bass heavy from 80hz down. It extends to 30hz but is NOT well balanced.
2. . The system has NO CONTROL, other than overall volume, of frequencies above the ~80hz crossover up to ~600hz.
3. The EQ LOW band is a low pass sub only.... 80hz and lower. The MID band is narrow and centered around 1khz. The HIGH band is 4k and up.
4. The 80hz to 600hz region, which is unaffected by EQ, is -10db down and the result is unintelligible bass since the fundamental notes are suppressed. It yields a scooped bass with a fat sub bass but doesn't have articulation or clarity. The sub bass around 40-60hz is +6db and combined with the -10db mid-bass, sounds boomy to my ears. Listeners accustomed to artificial bass ("Bass heads") might like this but it is not a realistic reproduction of the original recording.
5. The highs have a narrow +4 db boost around 10k that can't be addressed with EQ since the HIGH band adjustment is a high pass at 4khz.
6.. Optimal settings to my ears are Bass -6 Mids -2 Highs 0
7. Overall volume is loud and fairly clean at 38 (max) with the EQ settings I used. Measured max volume is 102db. It's not like sitting 10 rows back at a rock concert but plenty loud. Bass response (compression) is lost when any window or the sunroof is open. That is expected.
The system has good coverage throughout the cab. The best listening position I found is the center of the back seat.
The system could be tuned much better than it is...if a 5 band or more EQ was available. The DSP in the amp probably has the capability but I have not found any method to access it.
Overall, it sounds pretty decent. No audio system is perfect. Ever.
Note: I used an app called AudioTool for Android that I calibrated to my studio monitors that have a known response. I let my ears guide me but I like to confirm my findings with an analyzer.
TSB 08-123-18 made me very happy with the volume.
I asked for all updates and recalls associated with my truck while i was in for service . I got the ABS one done. after coming home and reading this fine forum i found out about the Amp TSB radio flash. i called the dealer and was told you didn't complain about the radio so they didn't upgrade it. Will be upgrading it at next service. than you to the member that brought this to our attention.
There is an update for the HK 19 speaker system. Make an appointment at service. Got mine done today and it sounds way louder and bass hits.So I called FCA about the H/K sound system, y told them I was really disappointed with the quality of this “premium sound system”. I ask the guy if I could bring the truck to a dealer to see if they can do something about that, I bought a 65000$ truck and my 50$ sound bar sounds better. So he said that the engineers are working to solve this issue because I’m not the only one. He said that before this year end an update will be available for the system, so I replied to him that I’m not an fca engineer (in fact I’m a computer engineer) I feel really that it’s really hard to download a physical mosfet and attach them to the amp outputs, so he said that they can do it , at that moment I realize this will be a long road. Anyways i explained to him that i meant that there’s a lack of power in the sound system, there’s nothing a software can do there. So far I think I have to wait.
Glad your sound system is improved. Mine actually sounds great, I just think it is causing the center rear sliding window to vibrate so it sounds like a vibrating speaker. Would you mind adding a signature and including your build date? It helps people see what updates they may need as well based on their own build date.There is an update for the HK 19 speaker system. Make an appointment at service. Got mine done today and it sounds way louder and bass hits.
