Aftermarket solutions being and hi end input signal processor and amp to run the sub independently? The sub can be so much better with a proper tune. Not sure audio control makes a line input, processor, and eq all in one to handle that job
392 - what amp are you using to power the factory sub? You using a PAC as well at the HU? Agree it hits decent when its low but just gets way to high in the range. I have it disconnected now, but upgraded full infinity Ref. If I could get a little bass out of the doors by dropping the EQ a couple ticks and back into the sub I think it’d be good.
I am using a PAC AP4-CH41 behind the display to send a flat, high level signal to one of the latest Kicker CX800 amplifiers which is small enough to be tucked behind the back seat without needing the seat reclined. The PAC is set to ignore the EQ adjustments done on the screen. You can then tune the sub a bit using your amp adjustments. The PAC does not send active noise cancelling through its signal. I snipped the factory subwoofer wiring a few inches back from the connector, and spliced it into new wiring going to the Kicker, which lets me keep using the factory subwoofer connector.
I chose the CX800 because it was only $75 more than the CX400. Supposedly the HK subwoofer is 6 ohm/204 watts, and if that's the case, you'd likely want the CX800 anyway because the CX400 would only be good for about 125 watts at 6 ohms.
In my previous 2019 Limited, I had replaced the door 6x9s with Infinity components which dramatically increased their bass output. But this also led to a lot of rattling in the doors despite TONS of effort to fix it (foam, dynamat, felt tape), so I had to notch down bass in the EQ to about -5 to get it to an acceptable level. This also meant I had to kill the active noise cancelling, because it caused humming in the Infinity 6x9s.
In this truck, for now I have left the HK stock 6x9s in place, and set the bass EQ to around +5 (because the bass EQ adjustment only goes to the 6x9s now) to bring more life to them. Things sound pretty good like this. ANC still works, probably not as effectively since the sub isn't used anymore, but I'm happy with it. I also put Infinity 3032s in the dash. They won't fit in the front doors without cutting because they are too deep, so I've kept the stock 3.5s in the doors. You can also put 3032s in the rear headliner if you want, but I never noticed much benefit from that in my last truck since the output up front is mostly what we hear, and it also requires you figure out the placement that will fit and drill new screw holes in the plastic speaker mount housing.
