@Dusty,
  You obviously work for a dealership as a technician of some sort. So you're saying that too much backlash with cavitation won't cause any vibration. Nonsense, I was a gas turbine mechanic who was trained and certified in vibration analysis who disagrees. All, after driving the truck a little more changing the rear upper and lower link bars made a huge difference. I centered the rear end and corrected the pinion angle. Yet I'm still plagued with a very minor constant vibration. The reverberation/jitter has finally been addressed. What I mean by that is when I drive over sudden impact bumps and transition from blacktop to concrete surfaces the truck now absorbs the shock immediately and dissapates, before the truck kept shaking. I measured the front end to check the alignment and it's off a quarter inch to the rear on the driver's side compared to the passenger side. 2nd dealership also addressed all 4 brand new Toyo A/T III's are out of round, 1 of them is pretty bad. In my opinion the vibration is now coming from the front. It is apparent that I've been chasing multiple problems and eliminating them 1 by 1. I remember the alignment shop attempted 6x's trying to align the front end the last time. This alone could be the source of the vibration. It can also be the source of the tire chopping along with the previously misaligned rear end. To recap my journey down the rabbit hole I've had every front and rear suspension component replaced except for axles, brakes, and wheel bearings. Replaced rims and tires 5x's with Roadforce balancing each time. Front end alignment probably 6x's. Had driveshaft balanced which was out of balance, and rear U-joint replaced. Installed adjustable rear upper and lower libk bar's. Aligned and centered the rear end. Adjusted and corrected the pinion angle. Finally, getting rid of this piece of **** Lemon, losing thousands of dollars replacing **** because RAM DOESN'T CARES along with a voided powertrain warranty trying to fix your truck! Well, this second dealership has gotten a 2021 RAM REBEL 4x4 Night Edition and offered to basically buy my truck back for what I owe on it, pulling the trigger today if this new truck drives normal! Lemon law is still in play as well.
