Rayzram
- Aug 5, 2018
The cab mounts are not the culprit, they can't possibly be the culprit. NVH issues require 3 things in order to be an issue.
1. A source, This has to be something that is moving or rotating in a cycle. Like a tire, rotor, drive shaft etc.
2. A transmitter, this is the path the vibration follows, control arms, frames, bushings mounts etc.
3. A receiver, This would be you in the drivers seat holding the steering wheel.
Remove any one of these 3 things and the issue goes away. The easiest fix is #3. If no one is in the truck to feel it then there is no one to complain about it, this is not an option though. The cab mount will fall under #2. If indeed they can eliminate the transmission path by changing the cab mounts, you will no longer feel the vibration but the culprit ie the source will still be there. It's also not engine or exhaust related. Through my testing the vibration frequency stays them same at constant speed regardless off what gear the transmission is in. A detected vibration frequency has to match the frequency of the source a change in engine RPM would result in a change in the detected vibration if it was indeed the source, which it doesn't do.
The 2014+ GM half ton trucks had the same issue and GM never admitted to a problem and to this day the source is still unknown and there is no fix. I had the vibration issue in my 2015 Sierra and spent 1000s of dollars and numerous hours trying to fix it to no avail. I will never buy another GM product because of the way they handled it. I'm hoping RAM doesn't handle this issue in the same manner.
From a 32 yr veteran auto tech, I can almost 100% assure you mine is not driveline such as rotating driveshaft, rotor, wheel/tire. I am putting my money on engine. Mine is RPM, NOT speed related. The only thing speed plays in it is hitting the right speed to get the engine between 1400 to 1600 rpm's. Mine is worse loaded at 35 mph @ 1500 rpm's then it is at say 65 mph at 1800 rpm's. Tip in throttle flat road and let it roll through into higher gears (creating heavy engine load) and when it gets to 1400 rpm's it begins, and will continue through 1800 rpm's. Ford, Toyota, Lexus all have suffered from this same type vibration. Here is some reading material Toyota is fighting, simply search tacoma 2000 rpm vibration and your search will explode with concerns and links. https://www.tacomaworld.com/threads/possible-solution-for-1800-2300-rpm-buzz.502272/
Here is the Lexus battle right now. https://www.clublexus.com/forums/gx...8-vibration-from-engine-at-1800-2000-rpm.html
