Brain h
My thoughts exactly.The fact they are going to pay out over 7K leads me to believe its not the wheel that's causing the issue and Ram knows or has a suspicion of what the issue is and it costs more than 7k to repair.
I have a 2019 tradesman 5.7 3.21 gears and I have this issue. The vibration comes at very low RPM’s (1200-1500). It feels like when you leave a manual transmission in too high a gear. I did not read all 24 pages of the thread so I apologize for anything I’ve missed, but after reading 1-4 and 23-24, it didn’t sound like there is a resolution yet.
Many of the theories about wheels, tires and exhaust can probably be ruled out. My truck has 18” rims and Bridgestone tires. Being a tradesman it has a single exhaust pipe.
If the engine is not “lugging” at the low rpm range the vibration is not present. Last night I experimented with bumping it down one gear when it happened, and the vibration went away. I will be seeing a dealer about this, but I’ve been incredibly busy with a new job and my kids’ sporting events and just haven’t had time.
I have a 2019 Lonestar 1500 and it I noticed the vibration with the factory 20 inch rims and after I purchased a new set with bigger tires from Discount Tires. I thought it was the wheels and/or a missing weight but nothing changed after I bought the new rims and tires.Anyone else?
I've been having a similar problem. I've taken it in 3 times to the dealer and got the whole "this is how it drives", or "seems normal to me" load of crap.
Today I took it in for a 4th time and finally got to work with the tech. Very nice and professional. During our drive he literally said, "yeah, you're right. It's definitely bouncy." Finally someone who doesn't act like I'm crazy!!
He told me that he'd first check out to make sure nothing is broken. If nothing is broken he said he'd then test drive another new truck to see if it's engineering related (problem with the design, not with the parts/implementation). Then we could discuss other options to fix it (new tires/shocks/etc).
I just heard back from him and he said that both the left and right vibration dampers were sending false signals (MDS I'm assuming). Basically they could be on when they shouldn't be and/or off when should be. He ordered new parts that should be in on Tuesday. After he installed them he said he'd test it again to see if that fixes it. If not he'll keep looking/testing until it's resolved. So far I'm very impressed with him and hope this finally fixes it!
So I have an update on mine and I must say I think I might’ve been wrong in my initial post when I ruled out exhaust. So the usual slight vibration and subsequent dash rattle continued the same until yesterday when my kids and I drove home from my son’s football game. There was a late 90’s Buick in front of us which I thought had exhaust issues. It was very loud. Then I realized it was actually my truck. In addition to the loud noise, the vibration was stronger. And it continued at various rpm, although seemed to dissipate if I stepped on the gas a little. This continued for about a 20 minute drive.
All my temperatures seemed normal and I got no codes, which seemed strange. It had me wondering if I had a loose/leaking exhaust manifold or other connection, which I thought would’ve triggered a sensor. The strange thing is this morning the loud noise was gone. We did quite a bit of driving both in town and on the interstate and only had the “slight vibration” issue today. Last night I got under the truck to see if I could see anything obviously wrong with the exhaust, but couldn’t see anything. The manifolds are basically surrounded by heat shields so access and visibility are very limited.
Several of us here have already unplugged the mds dampers and the vibration persisted. Mine seems to have the vibration around 56-59mph in both v8 and eco mode.Update: just heard back from the dealer that only one MDS damper arrived. The other won't arrive for another two weeks so they won't swap them out until then. I send another update once they arrive and are installed
Actually, disconnecting the dampers and the problem persisting seems like evidence they may not be working.Several of us here have already unplugged the mds dampers and the vibration persisted. Mine seems to have the vibration around 56-59mph in both v8 and eco mode.
Regards,
Dusty
2019 Ram DT 1500 Silver Billet Laramie, Quad Cab, 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33 gallon fuel tank, 18 inch wheels. Build date: 17 April 2018. Now at 021103 miles.
In your case I would say that eliminates the MDS dampers as the culprit.I disconnected the dampers on the frame rail between the doors AND deactivated MDS via manual gear selection....no change in vibration for me.
So have I. From what the tech said the problem is that its firing when it shouldn't and not firing when it should. Unplugging them would only solve the first problem, not the second. I'm not saying this is 100% the problem. I'm just passing along the information I've received so far.Several of us here have already unplugged the mds dampers and the vibration persisted. Mine seems to have the vibration around 56-59mph in both v8 and eco mode.
Hi elburrito82,
We certainly understand your frustration, but are happy to hear your dealer is taking steps towards a resolution. If you need any additional assistance, please feel free to send us a private message.
Hi Kellen O,
We're sorry to hear that you are also experiencing this. If you decide to visit your dealer to have this addressed, our team would be happy to connect you with a case specialist to work with you throughout this process. We are available via private message!
Alex
Ram Social Care Specialist
Thank you, I appreciate you reaching out. I went to the service department first thing Tuesday morning and they couldn’t get me a loaner until the 16th, so that’s when I’m dropping it off. I’ll keep you posted.
