Sinister04L
- Jan 1, 2019
Pretty sad that you have to pay out of pocket for new tires on a brand new truck just to get it to drive like it's supposed to.
Mine was pretty much immediate. Mine wasnt a violent bouncing at 70 like PTRAM, but more of the slight floorboard shimmy that tended to shake seats at 53 to 65 area.Quick question to those that are experiencing this. At what mileage did you start feeling it? Was it from the beginning or like myself, right around 3000 miles? I’m just at over 4000 miles and mysteriously it hasn’t done it in 3 weeks. It’s just as smooth at any speed just like it was when I drove it off the lot. While I’m glad I haven’t experienced it in that time, it does make me wonder what it could’ve of been and will it return? Hopefully somewhere along the way there will be an answer.
A given tire pressure, even when all 4 are equal, in my experience, can be smooth at one temp, and then, even if all equal still, but temp conditions are different, could be a shimmy.Mine was pretty much immediate. Mine wasnt a violent bouncing at 70 like PTRAM, but more of the slight floorboard shimmy that tended to shake seats at 53 to 65 area.
But it was pretty much immediate. I tend to take long unneeded trips after I get a new car just to bond with the new baby. Forst real highway use it appeared. I didnt think much of it because highways surfaces differ, and DC area cant make a flat road to save its life.
Some lanes are semi hauler used more than others and they create sunken dips in surface that you cant see well. So I attributed to that too. Once I realized I was making excuses for the truck, and after allowing 1000 miles (for the brake squeal bedding as well), I took it in.
It was immediate. And I knew it was alignment/balance plus tires that sat for 7 months without moving. After getting back, its solved, with what I pretty much confidently feel the remaining is tires. And I can handle that.
The come and go vibrations in my experience usually amounted to excessive mud dried up inside rim, since I do some of that kind of driving, and tire psi...since temps change and change those variables on a whim.
Mine isn’t the violent shaking either. Like you said the shimmy in the floor and the seat. My truck only sat on the lot for about 2 months. I never experienced it till I got close to 3000 miles. Now I’m a bit over 4000 and it hasn’t done it in weeks. Temperature around here has been unusually warm till this week and it hasn’t affected the truck. I used to think maybe it was when it was cold out, but now I’m not convinced of that. I hate the idea of having to shell out money for new tires if I don’t need to. Next time I have mine at the dealer I’ll have them check the alignment and see if it’s within specs. I’m more at a loss on why it’s stopped doing it now.Mine was pretty much immediate. Mine wasnt a violent bouncing at 70 like PTRAM, but more of the slight floorboard shimmy that tended to shake seats at 53 to 65 area.
Heres the thing, my truck was grossly misaligned from factory. That I know is fact. And logically I woukd assume others leave factory out of spec (why and how that happens, idk, and it ticks me off, but anyway). I assume out of the 500,000 tbey made, a good slew of them on roads are also out of spec and shoukd be looked at.Mine isn’t the violent shaking either. Like you said the shimmy in the floor and the seat. My truck only sat on the lot for about 2 months. I never experienced it till I got close to 3000 miles. Now I’m a bit over 4000 and it hasn’t done it in weeks. Temperature around here has been unusually warm till this week and it hasn’t affected the truck. I used to think maybe it was when it was cold out, but now I’m not convinced of that. I hate the idea of having to shell out money for new tires if I don’t need to. Next time I have mine at the dealer I’ll have them check the alignment and see if it’s within specs. I’m more at a loss on why it’s stopped doing it now.
And what speed does it begin, ejd and where is it the worst.Tires: 275/55R20 All Season Tires
Wheels: 20.0-Inch x 9.0 Inch Aluminum Chrome Clad Wheel
Received \ Starting Ownership Mileage: 354
Starting Mileage: ~500
Occurring conditions:
Temps: Between 65F to 5F since owned. Occurs at all ranges over the last 46 days of ownership (only had vehicle in possession for 29 days ; 17 at dealership).
Wx Conditions Occurring: Have had all types: dry \ clear, rain, snow (slush, falling \ fluff, hardpack), icy, sunny and night time, mostly cloudy, partly cloudy, mist, fog, haze, etc.
Road Types: Newly paved and old \ existing concrete, asphalt, bituminous.
Vehicle Conditions:
Occurs whether just started or has been running. No changes over trip distance or engine use.
Other Notes:
Experienced over heavy \ hard-packed snow this weekend on the expressway traveling at "safe speed" which the GF did not enjoy at all (gets car sick with the bouncing).
Basically it feels like you are going over packed snow that has some spots bare \ melted or driving at speed with a crapload of snow \ ice built up under your truck.
The search continues....
What has your dealer come up with if anything? Seeing this issue seems to be widespread among different size tires and brands of tires, I’m seriously leaning towards a suspension issue. Like I posted earlier mine has mysteriously stopped about 3 weeks ago, but that still doesn’t make me feel confident it won’t come back. Personally I’d rather have someone come across a faulty part so at least we’d have the answer to why. Still holding out hope that some mechanic taking a look at this issue will stumble across the cause.Tires: 275/55R20 All Season Tires
Vehicle Conditions:
Other Notes:
I know in my case I didn’t even have to look at the speedometer to know I was close to 55mph. From there till about 65 it would be there. Get above 65 and below 55 and it was smooth as glass.And what speed does it begin, ejd and where is it the worst.
I read that it occurs during all scenarios. That said, is it constant 24/7, or periodic during each of the scenarios..
In other words, have you EVER had a smooth ride.
Hopefully this solves your issue. How did they come to the conclusion you had a couple bad rims. The reason I’m asking is I brought that up to my service manager and he assured me mine where fine and that road force balancing them would’ve showed if they or a tire was bad. Not buying that but didn’t have time to sit and argue it with him.Update: After 5 visits my dealer has put Michelin Defenders on the vehicle. During the install, another rim was discovered to be out of spec. It will be here later this week.
I had to have the truck this week so I took it with 3 new Michelin's and one Goodyear with a bad rim and no TPMS sensor.
The truck must have been sitting for a few days, because when I pulled out of the lot, oh my god the shaking coming from that one wheel was violent at 60. It was almost like I tied a brick to one of my wheels. The jostling didn't subside until about 10 minutes later when I got on the highway and got everything warmed up. Now it's back to it's usual vibration at 60.
So just waiting on this one last rim and hopefully all should be resolved.
Me IRL:
I am not real thrilled about it either, but my dealer probably will not get any money from FCA so I am happy that they at least worked with me and gave me the deal that they did.
