greatone99
- Nov 30, 2018
update on mine ,did it 2 times first 450 miles ,has not since ,1700 miles now.
Do they sound like they're aware of the problem or know how to fix it when you scheduled the appointment?Mine did it again today. Was not as abrupt as previously, but maybe I'm getting used to it. That's four (4) times now in about 750 miles - twice going from P into D and twice P into R. Have service appointment in 4 days to get it checked at Dealer.
Nope. Will know more after my appointment to have it looked at by the Dealer tomorrow.Do they sound like they're aware of the problem or know how to fix it when you scheduled the appointment?
Well add me to the list as well, 4 days old and less than 200 miles. It happened on level ground going from R to D. I have an appointment tomorrow for them put my new tires on, I will let the service manager know... 2/12 Build Date
Thanks my appointment is next Tuesday... however when i called and mentioned the TSB they didnt know what i was talking about :/@ALBOY29 I got the TCM update about a month ago. Haven't had an issue since update . No valve body replacement needed. Still original VB. The P to D issue happed quite often when I first got the truck, got update around 1500 miles, now have over 3000. Coincidence maybe... or the issue truly got fixed with the update.
Can you please update us ?Nope. Will know more after my appointment to have it looked at by the Dealer tomorrow.
I'm planning to show my dealer the info. highlighted in this post from @Ghinesley . However, I could not find that TSB anywhere online.***UPDATE ****
Been driving my truck most of the day, many stops, turn off/turn on, P to D scenarios, smooth as butter. I was having an instance almost every day. I know its first day, but so far it all feels the way it should.
Here is what they did according to service record:
TSB 21-002-19, Flash TCM from 68360086AK to AL from 1/9/19 TSB. Topped off trans fluid (found to be 3/4 quart low from factory).
If you haven't already, get the software update and have the tech check the trans fluid properly. I'll continue to report back as I drive it more. Probably going to roll 1,000 miles tonight on the way home.
GUYS THE FIX FOR THIS IS A NEW VALVE BODY OR A NEW TRANSMISSION!!! I had a new transmission put in at 200 miles and now it has not done it once since putting in... ANOTHER GUY HAD A VALVE BODY PUT IN AND IT FIXED IT... so either or seem like a fix to me! pleaaaaaaaaaaseeee take videos and THIS THREAD to your dealers... open a case with FCA.... they have been a big help with getting my issue resolved!!!!
agreed!!!The fix MIGHT necessitate those things. For some of us, it did not. I had it 3 times in the first 500 miles. A PCM/TCM update was applied by dealer and I have not had it again and I'm over 3,000 miles now. Definitely take videos to show your dealer so you don't get the "can't replicate" BS and loop in @RamCares so they can work with your dealer and FCA to get it resolved. At some point I have to think FCA will pinpoint this issue. For now, I'm just happy the PCM/TCM appeared to help my particular situation.
