Dusty1948
- Jul 14, 2018
- Location
- Rochester, New York
No, I wasn't even aware of the TSB went I went in for service.Awesome. Thanks for posting.
Did you take the TSB #/printout in with you when you brought it to their attention "rough idle on cold start".
or
Did the tech find the TSB based off the concern?
I mentioned something about this before, but I didn't have an appointment. service advisor was unwilling to look up anything related.
I talked to the technician directly after he asked me a question regarding the symptom. During my presence he went into the diagnostic routine to check on things, and he followed a thread in the diagnostic that led to a symptom/problem area of the procedure. He found the symptom even though the symptom or the TSB did not apply to my DT based on VIN. Intuitive thinking led him to flash the PCM based on the symptom (He's got 20+ years servicing Mopars.).
You are correct, this particular TSB does address a number of issues and I don't remember if rough idle was actually spelled out in the TSB, but it was on the diagnostic screen.
As an aside I asked the tech. why he applied the flash since my VIN fell outside the range of affected vehicles. I have to paraphrase, but basically he said that sometimes they miss VINs because they were held back on the line, or at the particular assembly line station the PCM (or other modules) didn't get the full download.
All I can tell you is it fixed the issue.
I hope this helps.
Best regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33 gallon fuel tank, factory dual exhaust, 18” wheels. Build date: 03 June 2018. Now at: 039706 miles.
