StuartV
There is way too much here for me to be interested in replying to. Let me sum it up like this. There are no spreadsheets listing the cost. We all know that. Our projections are obviously predictions as opposed to figures released directly from Ram, but based on the price of other EVs in the marketplace, batteries are extremely costly. Then you will have to pay for that battery a second time if (like me) you keep your trucks for 20+ years. On top of the battery costs (which are already exorbitant), you have the extra costs of maintaining a regular v6. Of course this double cost (battery + engine) is going to cost you more than maintaining a hemi, we don't need a spreadsheet for this its simple logic.
"Simple" logic. The same kind of logic others use to "explain" why banning some things will reduce certain statistics....
You are assuming that the maintenance of the V6 will be on the same schedule, with the same costs as it is now, when the V6 is used as the only motor in a RAM 1500.
I don't think that is reasonable at all. So, the "simple" logic does not hold up to the "complex" reality.
The cost of maintenance of a V6 used as a generator (in a plug-in EV) for 20 years should be far lower than the cost of maintenance of:
V6 used as only drive motor
transmission
transfer case
torque converter
front and rear differentials
auto-locking hubs
What we've been told so far is that the generator is "130kW". That is 174 HP.
Having the Pentastar motor tuned to output a max of 174 HP and only running part of the time the vehicle is being driven (and not always at max output) (for MOST Ramcharger owners) should result in extremely high reliability and much lower maintenance necessary on a per-hour-of-runtime basis. And with it only running a fraction of the time the vehicle is being driven, the cost of maintenance of the gas engine should be a small fraction of the cost of running a Hemi as the only motor for the same number of vehicle miles.
In 72K miles of ownership, I spent $1,000 (very close - the total is $3,921.58, but that includes approximately $3K spent on wheels and tires during that time) on service for my '19 RAM 1500 with Hemi/eTorque. That was just oil and filter changes. I didn't have it long enough to have any of the big service/repair bills. No transmission/torque converter/transfer case/diff servicing. And no charge for the exhaust leak that was repaired under warranty.
How much you reckon I would have spent on a Ramcharger Pentastar in 72K miles and 3 years? I'm guessing just 3 oil changes and that's it. So... $150? Save $250 a year on maintenance and that's $5000, over 20 years. And that doesn't count how much you save on "fuel", or how much you save by not having a transmission, etc, to service and fix during that 20 years.
So... is a Ramcharger REALLY going to be more expensive over a 20 year period of ownership?
I think that remains to be seen, and all the assertions that "simple logic" tells us it's going to be way more expensive are just, well, hot air. Wild speculation not based on any actual data being analyzed.
