Well, I got my tank replaced last night. Took about five hours. We lost a lot of time primarily on five things: 1) those chassis clips holding the fuel and brake lines, 2) the two fuel line "quick" connects on top of the fuel pump, 3) those retainer clips for the heat shield, 4) getting the fuel inlet hose attached to the new tank, and 5) figuring out AlphaODB.
We took our time since we absolutely did not want to break any plastic pieces.
1) The chassis clips were just a pain even though we had an idea how they worked. As noted in a previous post, you gotta put a pick or ultra small screwdriver in there to pry the hook to release it. We took our time; we didn't want to break them.
2) Those fuel line connections on top of the fuel pump are different than all the rest. Turns out you slide up the retaining clip and push on the opposite side with your thumb (turn sideways for better access) to release.
3) The heat shield clips just needed a pry tool (or putty knife) slipped under the head to pull it up in order to release. Easy peasy, but not totally obvious looking at them.
4) The fuel inlet hose was just massively difficult attaching to the new tank as we didn't want to put grease on it to slide better in case grease got into the fuel tank.
5) The AlphaODB software changed a little bit since Dixit's write-up on the other thread, which slowed me down. After successfully connecting to "My 2019 PowerNet" but before any other steps, you have to tap the diagnostics button at the bottom right. This takes you to the screens for changing the fuel quantity as shown in Dixit's write-up.
When you disconnect the high-pressure fuel line, I'd say about half a cup of fuel comes out. Just be prepared for that.
We've not attached the third strap yet. When we got the 33g tank mounted securely, I pulled down pretty hard on the forward end of the tank and it seemed quite secure. I'll evaluate it again when I change the oil in a couple months.
In other news: When we were putting the new fuel pump into the new tank, we found something rolling around inside the tank (see attached pic). We have no idea what it's for; doesn't seem to belong to the tank. We think it got tossed in there at some point before reaching me. When the tank was delivered, the box had been compromised. It's definitely a check valve but my 23g tank doesn't have anything like it. Anyone know what it is FOR SURE?
I wish everyone great success at their project!
