Dixit
- Mar 20, 2019
@RJS fully agree with you on the strap there, I like that you measured it as more proof on the length of the area left unsupported. I know in that other thread where a member had the dealer do it and the techs claimed it will be fine without, I call straight BS on that. Techs dont give a crap about that part. Last thing i want is you do a hard brake and the fuel slosh slams one way and snaps the plastic in half cause of all the area unsupported.
As far the pump, Im not convinced on why they think its the same. Id like to see both side by side to see what the differences are.
As far as the reprogramming needed, only thing that needs to be done when i compared my truck config with my dads (exact same year same model Limited except his has a 33gal), only difference i saw was Fuel Capacity size which i changed on my mine to match using AlfaOBD. The fuel tank level values were not adjusted since the 26 and 33 gal tank area identical depth wise and even shape except 33gal has extra length towards the front of the car. So tank level sending unit didnt get affected or change.
