Chris3058
Just had mine replaced under warranty. 2020 Rebel. There is a star case here.
https://static.nhtsa.gov/odi/tsbs/2021/MC-10187092-9999.pdf
I need to read through this whole thread but has anyone gotten this covered under max care extended warranty for CPO? Mine is leaking on my 2019 ram 1500 limited and they just called me saying it is not covered. The car only has 31k miles on it and I have the 7 year 100,000 max care warranty that I bought. Any suggestions?
Contact Ram Customer Care. It looks like they are going to take care of me. But, I also has the Push button Start Module get fried from the leak.I need to read through this whole thread but has anyone gotten this covered under max care extended warranty for CPO? Mine is leaking on my 2019 ram 1500 limited and they just called me saying it is not covered. The car only has 31k miles on it and I have the 7 year 100,000 max care warranty that I bought. Any suggestions?
I'll go this route if needed. If the cracks get bigger I'll repeat the process. There has to be a theoretical limit as to how much bigger those cracks can get.Has anyone actually done the permatex that has had the cracks and been able to confirmed it works in the long run? The cracks get bigger over time so I'm interested to see how that will affect it.
I may not be a good test case because I live in West Texas where it hardly rains, however, I added Permatex back in November and after multiple car washes, still no leaks.Has anyone actually done the permatex that has had the cracks and been able to confirmed it works in the long run? The cracks get bigger over time so I'm interested to see how that will affect it.
I will. My car also was in for the RF hub issue (which is being replaced) and I think that issue was caused by the leaking window. Is ram customer care the 1-800-992-1997 number?Contact Ram Customer Care. It looks like they are going to take care of me. But, I also has the Push button Start Module get fried from the leak.
844-888-0601I will. My car also was in for the RF hub issue (which is being replaced) and I think that issue was caused by the leaking window. Is ram customer care the 1-800-992-1997 number?
It sounds like the same hub/module issue I’ve seen in other forum posts. The module that communicates with the keyfob fails and so the car doesn’t respond to anything .What’s the RF hub issue. Would that have anything to do with remote range? Cause mine sucks royally. Like 6 cars away it might work.
Do you have glass coverage through your insurance?Just got off the phone with both mopar vehicle protection and ram customer care and neither is going to help me with this leaking window issue. This is really disappointing and really has just solidified we won’t be buying a mopar car ever again.
My car was bought CPO and I bought the 7yr/100,000 mile extended warranty. Ram customer care said I don’t qualify for any goodwill (which apparently works if you’re within 2 years or 24,000 mi after your factory warranty lapses BUT you have to be the original owner apparently). So because I’m the 2nd owner the goodwill doesn’t apply (note: my car is actually only 10 months passed the original 3 year warranty and actually 5k miles BELOW the original 36k mile warranty - but because I’m not original owner then the goodwill doesn’t apply).
The things that frustrate me are:
1. As a consumer I thought I did all the right things when buying this truck used - I made sure to buy CPO and made sure to buy the extended warranty direct form mopar. Yep somehow I’m still screwed for something that shouldn’t happen in a car - water leaking into it.
2. If we don’t fix this leak, the other issues they are fixing (such as the fried module) wound just happen again later if the leak is still there!!!
3. It’s crazy to me that this doesn’t cover under my extended warranty. I get it won’t include like glass cracks since that’s wear and tear - but the actual thing that holds the window in leaking? That seems like a defect that should be covered.
4. My extended warranty only covers 5 days of rental? What if the dealership needs it longer because they need a part, etc? I’m just out of luck?
Anyways - any other suggestions on how to resolve?
Lawyer?Just got off the phone with both mopar vehicle protection and ram customer care and neither is going to help me with this leaking window issue. This is really disappointing and really has just solidified we won’t be buying a mopar car ever again.
Buy the light and replace it yourself. You should be able to get a new Mopar light for less than $50 shipped.The dealer just called and now they are saying they actually think the leak is from the third brake light. It’s a $270 fix and they said still not covered under warranty.
