Rear Fog Lamps
guys, if you want to have the amber rear fog lights symbol (showing on the lefthand side of the center screen) you need to change the country code from USA to something different in the bcm via alfa obd. For example: Canada
Changed country code to Canada "and just like that" I got the icon. Thanks, again.
@brental1 great news, I have to ask: did you notice any other side effects?
Just did. This morning, I discovered I have DRL. And, I guess because the headlights are on, the cluster (panel lamps?) lighting goes to night mode. Can override the panel lighting with the turn wheel in the brightest click.
I don't know how to turn DRL off; or if it can even be done.. There are several options.
Do you have a Tazer? I believe you can adjust the DRL settings with that.
I have Alfa OBD. Screenshot in above post.
I set
CBC Features -DRL Configuration to No DRL, and
CBC Features-DRL Lamp Location to None
and I still have Headlights on and Panel lamps in Night mode.
I set
Just noticed I also have DTL (I think it's called; Tail Lights)
I don't think so. According to Jimmy07, starting in 21, Canada required headlights and taillights constantly on (well, when truck is running). In my thinking, it's like that's hard coded in when Country Code is set to Canada. Can't be changed. (possibly cound be changed on 19 and 20 truckss) I'm going to try another country that allows rear fog; but doesn't require DRL and DTL.
Set it back to USA for now.
Have many Country Code options; and hundreds of Destination options.
@Jimmy07 as a resident expert, to see if there may be any workaround for this.
Gonna have to decide what you want more- to see the rear fog indicator in the cluster and have always on headlamps/tail lamps, or forget about the fog indicator so you can have lights work the way you want.
You start changing country codes, and it’s going to start affecting other configurations of the truck adversely.
All I gotta say is, if you’re gonna start messing with country codes, make sure you make a backup file and system ID log BEFORE you start changing country codes.
Good advice. Thanks.
Hello Sir
Is this orange-white cable that goes into the connector the one responsible for powering the planned fog light? On the other side of the connector, no wire comes out, so I just want to confirm.
If I go with a simplified setup and install a basic fog light myself with the following parameters: 12V / 0.2A / 2.5W (or 24V / 0.1A / 2.5W, depending on the system), where would you recommend connecting the ground (GND)? Can I simply attach it to the car’s chassis, or is there a specific grounding point nearby that would be better to use?
Hello,
I'm new in the forum and I'm planning to add rear fog lamps this way as it's the cleanest installation I have seen.
I'm having problem to locate this conector on the post from Saubs,
I know I have to use the white/orange wire from that conector.
I'm attaching one image with two conectors located just at the left of the spare wheel. Is one of these conectors or where I have to look for?
Hello,
Hello,
The left fog light feed is WH/OR, ground is BK, 0.75 gauge. The right fog light feed is WH/DG, ground is BK, 0.75 gauge. I don't know where these grounds finally terminate; but they should be available in your bumper harness. The connector you circled in blue is the bumper harness.
Hello,
    • Hello,
    • The left fog light feed is WH/OR, ground is BK, 0.75 gauge. The right fog light feed is WH/DG, ground is BK, 0.75 gauge.
I think Saubs was saying that the WH/OR and WH/DG are not present in his bumper harness. They weren't present in my original bumper harness either. I had to buy a different bumper harness which contained these wires. Also, it sounded like he was planning to use a filament bulb. The OEM fog lights are LED. Not sure if the circuits in the truck would like a filament bulb?
I connected the rear fog lights according to the instructions. They turn on with the original button, but the lights icon doesn't display on the instrument cluster. Does anyone know why? Do I need to enable it somewhere?
Thanks, I have now found that WH/OR and WH/DG cables on the blue-circled connector, with empty terminals on the bumper side of the connector,
I'm now looking for the terminals (I don't want to cut any cable).
I have ordered these: 1418885-1, TE Connectivity MCP 2.8 Male Terminals, 964972-seals,
have to check if they are the correct ones.
The red-circled connector is the one you need for the bed cargo lights. The terminals are the same but female, just FYI if it can help someone.
