Changed country code to Canada "and just like that" I got the icon. Thanks, again.guys, if you want to have the amber rear fog lights symbol (showing on the lefthand side of the center screen) you need to change the country code from USA to something different in the bcm via alfa obd. For example: Canada
Not yet. I will be flashing some other options to my truck and will try it then.
Changed country code to Canada.Not yet. I will be flashing some other options to my truck and will try it then.
Just did. This morning, I discovered I have DRL. And, I guess because the headlights are on, the cluster (panel lamps?) lighting goes to night mode. Can override the panel lighting with the turn wheel in the brightest click.@brental1 great news, I have to ask: did you notice any other side effects?
I have Alfa OBD. Screenshot in above post.Do you have a Tazer? I believe you can adjust the DRL settings with that.
Just noticed I also have DTL (I think it's called; Tail Lights)I have Alfa OBD. Screenshot in above post.
I set
CBC Features -DRL Configuration to No DRL, and
CBC Features-DRL Lamp Location to None
and I still have Headlights on and Panel lamps in Night mode.
Wonder if this may help: Disabling DRL's in Canadian trucksJust noticed I also have DTL (I think it's called; Tail Lights)
