Changed country code to Canada "and just like that" I got the icon. Thanks, again.guys, if you want to have the amber rear fog lights symbol (showing on the lefthand side of the center screen) you need to change the country code from USA to something different in the bcm via alfa obd. For example: Canada
Not yet. I will be flashing some other options to my truck and will try it then.
Changed country code to Canada.Not yet. I will be flashing some other options to my truck and will try it then.
Just did. This morning, I discovered I have DRL. And, I guess because the headlights are on, the cluster (panel lamps?) lighting goes to night mode. Can override the panel lighting with the turn wheel in the brightest click.@brental1 great news, I have to ask: did you notice any other side effects?
I have Alfa OBD. Screenshot in above post.Do you have a Tazer? I believe you can adjust the DRL settings with that.
Just noticed I also have DTL (I think it's called; Tail Lights)I have Alfa OBD. Screenshot in above post.
I set
CBC Features -DRL Configuration to No DRL, and
CBC Features-DRL Lamp Location to None
and I still have Headlights on and Panel lamps in Night mode.
Wonder if this may help: Disabling DRL's in Canadian trucksJust noticed I also have DTL (I think it's called; Tail Lights)
Gonna have to decide what you want more- to see the rear fog indicator in the cluster and have always on headlamps/tail lamps, or forget about the fog indicator so you can have lights work the way you want.@Jimmy07 as a resident expert, to see if there may be any workaround for this.
Good advice. Thanks.Gonna have to decide what you want more- to see the rear fog indicator in the cluster and have always on headlamps/tail lamps, or forget about the fog indicator so you can have lights work the way you want.
You start changing country codes, and it’s going to start affecting other configurations of the truck adversely.
All I gotta say is, if you’re gonna start messing with country codes, make sure you make a backup file and system ID log BEFORE you start changing country codes.
Hello,Hello Sir
Is this orange-white cable that goes into the connector the one responsible for powering the planned fog light? On the other side of the connector, no wire comes out, so I just want to confirm.
If I go with a simplified setup and install a basic fog light myself with the following parameters: 12V / 0.2A / 2.5W (or 24V / 0.1A / 2.5W, depending on the system), where would you recommend connecting the ground (GND)? Can I simply attach it to the car’s chassis, or is there a specific grounding point nearby that would be better to use?
Hello,
I'm new in the forum and I'm planning to add rear fog lamps this way as it's the cleanest installation I have seen.
I'm having problem to locate this conector on the post from Saubs,
I know I have to use the white/orange wire from that conector.
I'm attaching one image with two conectors located just at the left of the spare wheel. Is one of these conectors or where I have to look for?
The left fog light feed is WH/OR, ground is BK, 0.75 gauge. The right fog light feed is WH/DG, ground is BK, 0.75 gauge. I don't know where these grounds finally terminate; but they should be available in your bumper harness. The connector you circled in blue is the bumper harness.Hello,
Hello,
Hello,
- The left fog light feed is WH/OR, ground is BK, 0.75 gauge. The right fog light feed is WH/DG, ground is BK, 0.75 gauge.
I think Saubs was saying that the WH/OR and WH/DG are not present in his bumper harness. They weren't present in my original bumper harness either. I had to buy a different bumper harness which contained these wires. Also, it sounded like he was planning to use a filament bulb. The OEM fog lights are LED. Not sure if the circuits in the truck would like a filament bulb?The left fog light feed is WH/OR, ground is BK, 0.75 gauge. The right fog light feed is WH/DG, ground is BK, 0.75 gauge. I don't know where these grounds finally terminate; but they should be available in your bumper harness. The connector you circled in blue is the bumper harness.
Without digging into it, I would have to say that most likely not.Not sure if the circuits in the truck would like a filament bulb?
