Lack of grease in the rear area of this strange design of a drive shaft. You have to remove the rear end of drive shaft (4 bolts, 2 bolts holding a support bracket toward middle). Then the clamp closest to the rear of truck on dust cover has to be cut off (factory locked), then the rear of shaft slides out from the ridged area and I'm sure you will find lack of lubrication. Grease it up real good and slide it back in. Waalaaa, mine is smooth as butter now, no more of the "Ram clunk".
