Can you send me pics of your cv joints. I had the full kit installed and the angles seem rather extreme. Center of hub to fender measured 22.5 before 3.5” sst was installed.Just had the readylift sst 3.5 inch lift installed on my Laramie with ORP. Shop that installed it said no problems. Does anyone know why readylift recommends not installing the spacer? View attachment 8325
The angles will be extreme with the ReadyLift 3.5” kit or ANY 3” level. Stay under 2.5 if leveling or get a kit that drops the crossmembers and differential.
Hi, If you want, I can send you pictures of my Rebel with (ReadyLift + Motofab). Tomorrow.Going to bring it back in and have preload spacers removed. Hoping this gets it into an acceptable range???
What do you mean by remove it? Like completely remove the spacer or put a smaller spacer in?Going to bring it back in and have preload spacers removed. Hoping this gets it into an acceptable range???
What’s the rake end up like? Would that be different than just pulling out the preload spacers?Hi, If you want, I can send you pictures of my Rebel with (ReadyLift + Motofab). Tomorrow.
Yea you will be good. I just wouldn’t drive it for a year like that.Readylift said to remove the preload spacer and I should be good. I’m new to this so any ideas? Am I ok to put a hundred miles or so with these angles until I get it in or should I park it?
Thanks for the input. Spacer comes out TuesdayYea you will be good. I just wouldn’t drive it for a year like that.
Please post some pics of your truck
Nice look! How much lift with that puck?View attachment 45126
Tires: 275/60/R20 (33") Goodyear UltraGrip Ice Arctic (Studded)
Still a stretched level which will kill front end parts.So if you take the 1" from off rd package springs and a 2.5 Motofab tophat =3.5 inch lift and just get uca for that lift. Has anyone done that?
Truck looks really good. Going with the 275’s probably helps the ride and mpg too
