So much great info out there...this forum can be a mind-saver! So in interest of saving my mind:
I have a '19 Laramie with Off Road Package. Interested in leveling the front, originally wanted ReadyLift 2" level kit. As pointed out in other posts, ReadyLift explicitly calls out that the kit is not recommended for trucks with factory ORP. I contacted ReadyLift via the website and here was the response:
I'm looking for a level kit with UCAs for a 2019 1500 4x4 with the "Off Road Package" and NO air suspension. What would you recommend?
We are recommending for the factory lifted 2019 Ram 1500s that you can use our 3.5" lift kit, but do not install the preload spacer. This will ensure that you have the proper UCA cup angles for the amount of lift the truck will have.
So...RL is basically saying to buy a full lift kit (retail for $900 on their website) and then only use the strut extenders and UCAs. I assume the strut extenders are the exact same ones included in the 2" leveling kit (with the additional 1.5" coming from the preload spacer). Are the UCAs in the 3.5" lift kit different than the UCAs in the 2" level kit? I'd hate to spend $900 ($690 on amazon) for a full lift kit when all I need are the extenders and UCAs.
Anybody have advice on how to get a front end level on a ORP truck? Which extender / UCA combination would you recommend. Not looking to be cheap...I believe quality is important. Just don't want to pay for excess hardware that I'm not interested in using.
