Readylift 3.5" kit on Offroad Package
I have 3" motofab fronts ruffcountry forged uca and 1" motofab rears waiting to install when it warms up I have the org also
Just had the readylift sst 3.5 inch lift installed on my Laramie with ORP. Shop that installed it said no problems. Does anyone know why readylift recommends not installing the spacer? View attachment 8325
Can you send me pics of your cv joints. I had the full kit installed and the angles seem rather extreme. Center of hub to fender measured 22.5 before 3.5” sst was installed.
The angles will be extreme with the ReadyLift 3.5” kit or ANY 3” level. Stay under 2.5 if leveling or get a kit that drops the crossmembers and differential.
Going to bring it back in and have preload spacers removed. Hoping this gets it into an acceptable range???
Hi, If you want, I can send you pictures of my Rebel with (ReadyLift + Motofab). Tomorrow.
What’s the rake end up like? Would that be different than just pulling out the preload spacers?
What do you mean by remove it? Like completely remove the spacer or put a smaller spacer in?
Readylift said to remove the preload spacer and I should be good. I’m new to this so any ideas? Am I ok to put a hundred miles or so with these angles until I get it in or should I park it?
Yea you will be good. I just wouldn’t drive it for a year like that.
So if you take the 1" from off rd package springs and a 2.5 Motofab tophat =3.5 inch lift and just get uca for that lift. Has anyone done that?
Truck looks really good. Going with the 275’s probably helps the ride and mpg too
I have a question.I know the Mopar lift comes with a rear track bar relocation bracket that raises the track bar slightly.Has any one had any problems with this lift without using anything like that.Thanks
