How do you run e85?For $799 it can be though!
If e85 ever goes back to half the price of 87 I’ll probably do it.
That's pretty cool.![]()
ProFlex Commander for all 5.7 HEMI RAM Truck
The patented ProFlex™ Commander adaptive flex fuel system for RAM 5.7 HEMI V8-equipped trucks allows you to start making more power and running cooler with E85. True plug and play flex-fuel for your RAM truck in about an hour with no tuning required. ProFlex Commander Features: Complete system -...www.advancedfueldynamics.com
Ya beat me to it.Work on your fuel math. E85 is 85%, but most pumos will guarantee 70% or better. E-88 is "up to" 15%. Most other grades are "up to" 10%.
Once again, nothing wrong or "cheap" running the fuel these mid priced mass produced trucks were designed to run on. No damage should occur from running the fuel they were designed to run on or they would not tell us it was designed for it and still warranty it.Difference between saving on the price of fuel you should be running, and just being cheap by running 87 to save a couple dollars. I also have to run 91 octane or better since I have the Pulsar.
Man, that sounds a lot like "nothing wrong with running 3.21s to move a truck that was designed to be moved by 3.21s. No damage should occur up to max towing capacity or they would not give us the max towing capacity and still warranty it."Once again, nothing wrong or "cheap" running the fuel these mid priced mass produced trucks were designed to run on. No damage should occur from running the fuel they were designed to run on or they would not tell us it was designed for it and still warranty it.
OMG! Not even close! With 3.21 you don't have a choice. With 3.92, it doesn't really matter.Man, that's sounds a lot like "nothing wrong with running 3.21s to move a truck that was designed to be moved by 3.21s. No damage should occur up to max towing capacity or they would not give us the max towing capacity and still warranty it."
Bruh, we only put the camper in a Walmart parking lot once and didn't even sleep there. Ate a football sized burrito, picked up a couple things at Harbor Freight, then went and slept at the ******* Barrel.OMG! Not even close! With 3.21 you don't have a choice. With 3.92, it doesn't really matter.
I guess you get a break for hauling your house from Walmart parking lot to Walmart parking lot though!(sorry, I couldn't help it)
You can press a button in your truck to replace the 87 with 89? Badass. Got a part number for that?On my old corvette I had 150 shot NOS plate. I guess when I took off from a stop sign without pressing the button I was handicapping my car.
I have that button! When I press it my seat gets hot. I guess it converts farts into 89 octane fuelYou can press a button in your truck to replace the 87 with 89? Badass. Got a part number for that?![]()
Why is cr@cker censored? LmaoBruh, we only put the camper in a Walmart parking lot once and didn't even sleep there. Ate a football sized burrito, picked up a couple things at Harbor Freight, then went and slept at the ******* Barrel.![]()
I dunno, but now I want some graham crackers.Why is cr@cker censored? Lmao
If that worked, I could fuel up at taco bell way cheaper than shellI have that button! When I press it my seat gets hot. I guess it converts farts into 89 octane fuel![]()
There seems to be some mistake confusing octane rating with quality for some strange reason. I am sure it is understood that this rating is just the burn rate.
You have chosen to override the factory programming and void the warranty by going outside the parameters and have your truck run on 91 or higher. That's a choice. Not a bad one, performance mods can be fun. I have a custom tune in my car. Just for kicks.
One of the guys who was the beta tester for that set up on his Scat Pack is a local friend. It worked great for him. He has since rebuilt his engine and still running the flex fuel set up with a custom tune. Once out of warranty I may look into it.Interested in hearing your take on this Pro Flex set up if you know anything about it.
Always wondered about the whole alcohol fuel thing. I mean, they run it racing right? It does not seem like you would run something with less power.I'm not confusing octane for quality. I know the difference and because of that can comprehend why 89 should be the preferred fuel when the owners manual recommends using it for optimal performance and fuel mileage. And also know that the reason you can safely run 87 octane is because these engines have knock sensors and will retard the timing to compensate for the lower octane. Hence me staying that you are handicapping the truck with retarded timing.
Have you been to Taco Bell lately?If that worked, I could fuel up at taco bell way cheaper than shell![]()
