OK, did a good test today... Ran through a touchless car wash. You know, the one with the nasty nozzles coming from every angle....
Only leaks came in exactly where I expected... Front and rear corners
I think the front is easily corrected by either removing the included weather strip bak provides or adding additional weather strip to fill the gap.
The rear might always be a problem, but some weather strip attached to the bed (not gate) to fill the gap could make a huge improvement.
The good news is that none of the water was anywhere except the corners and that was with high pressure nozzles from the side. Rain should be less invasive.
