Pics of your lowered Ram
The power running boards scraping the ground when they deploy? I have a southwest edition too and just got an IHC 3/5...
It gets close on uneven ground lol
Yea I just got an IHC 3/5 but haven't put it on yet. Running Boards look like they will be pretty close to the ground haha... but at least we can turn them off on uconnect rather than unplugging them. I really wanted just a 2/4 but I've just heard so many bad things about Maxtrac, so I went with IHC. Yours looks really good, makes me worry the 3/5 might be to low for me...
So far I like the 2 4 kit ride is a bit rougher in the rear but not to bad for me .
I wanted to go with the ihc kit as well but chose the 2 4 for the same reason as you mention ,didnt want to be to low.
I have the factory night edition 22s and tires and it only rubs cutting it hard to the right, but rubs a lot more backing it up left. I think I need a camber kit, I’m not sure what kit to get, can you gents help me out? I have the max trac 2/4 and the truck is a 21 Laramie 4wd
Or I guess my other question is, are the upper control arms the same on a 2wd and 4wd? Would the IHC adjustable uppers work on a 4wd?
Wow these look awesome! bout to pull the trigger on the 2/4 kit myself! any issues ill run into? not hauling or towing just daily driven !
I think it’s my front driver side tire that is rubbing, but that is most likely because of the camber being out of whack. Other than that, it feels like the driving dynamics has slightly improved and I love the look and all heads up she gets!
What rear 2” lowering springs would you guys say gives a ride that is closest to stock?
Max Trac sells just the 2 inch lowering springs. If you're not touching anything else it should drive like stock.
Thanks! That’s the brand I keep coming back to and my main concern with any options is ride quality.
Maxtrac 2" rear is comfy. Not sure if the BTS rear shocks (off road package) are stiffer than non off-roads, but they seem to be a really good match
Went down to IHC and had their service side JNJ Motorsports install the kit for me.. they did a great job.
Nice. I saw it on their Facebook stories. It's a beautiful truck. Did you ever get a chance to ask about the turning radius? I just installed my maxtrac back in the front and got my full turning angle back.
For me stock was 1 and 1/2 turns and with their kit I’m getting 1 and 3/8th so only lost 1/8th of a turn.. really not much was lost.. that’s fine with me…
