I removed the telematics box.  I don't think it was meant to be easily removed.  It was difficult accessing one of the bracket bolts towards the center of the dash.  All of the connectors are opposite the work side, so you can't see them to unplug them.  I found the grey one to be the most difficult. It's tied back so that you can't pull the box out much even after you remove the bracket bolts.
Knowing how to release the latch is benefit. Cutting its wire tie to give just a little more working room was necessary for me, then I could see how to push the latch to the side and unplug it.  Then you can pull the box out more and disconnect the rest.
After all that fuss, I installed my bypass and put the truck back together again.
So far, my performance, off road and trailer tow screens are all sticking!
And GPS and SXM still work.
So long big brother and sneaky sheety updates!!!
