silver billet
- Apr 18, 2019
Towing the 25’ Airstream, up long hills, often 5-6% grades, I’ll see the oil temp hit 250 easily. Up at North Cascades National Park, it touched 260. I thought that miles long steep climb old never end. I shut the A/C off when the coolant hits 230, and it usually goes back down.
the transmission rarely goes over 205, at least with the A/C off.
This truck has the 3.92 gears.
That is too high in my opinion. Things you can do to minimize that, remove the active grill shutters (debatable whether it helps but certainly doesn't hurt), replace stock tstat with a 180, and if that isn't enough go with an aftermarket cooler. The 180 tstat will give you more breathing room, so while climbing a hill you will still notice your temps increasing but generally it runs cooler all around so you start from a cooler temp and end at the top of the grade with a cooler temp.
I used to hit 250 towing, now after running a 180 tstat I hit about 230 max and quite often it sits at 220 to 225 while towing which is wear it sat unloaded with the stock stat.
Also if I were you I'd be running a very high quality synthetic 5w-30, Redline, HPL (several different products there), Mobil 1 FS 0w-40 are all good candidates.
