Cbty2050
- Dec 26, 2021
Middle, there is a circular indent in the bottom of the fuel tank you can see. Straight up from that pointNear the front or back?
Sent from my SM-G981U1 using Tapatalk
ThanksMiddle, there is a circular indent in the bottom of the fuel tank you can see. Straight up from that point
Don't worry bud, I told them to fill back to half which they did. Guess what? Gauge still says empty. Someone screwed up during the installationAs far as a fuel gauge reading empty when installing a new tank,
heck yes it's going to read empty untill someone fills it.
So unless the mechanis took it to a station and put in so certain amount it would read empty.
I would expect that they would only pour a 2-3 gallon cans worth when finished just to get it out of the bay.
Just a guess but I would say that the fuel tank sensor is part of the fuel pump inside the tank. I see no reason why they wouldn't make it all one unit.Don't worry bud, I told them to fill back to half which they did. Guess what? Gauge still says empty. Someone screwed up during the installation
Then in that case bud they should have taken it right back into the shop.Don't worry bud, I told them to fill back to half which they did. Guess what? Gauge still says empty. Someone screwed up during the installation
99% of the time the fuel tank sensor is just transferred to new tankThis must be either the worst dealer or I just have bad luck. After the fuel tank was replaced, the gas gauge no longer worked. I made the appointment to get it fixed for today. Last week the check engine light comes on. I pulled a P4056 code which is typically an Evap small leak code which I assumed was related to them changing the tank. I drop truck off today and they call and tell me the fuel sensor is bad and needs to be replaced and the engine light is related to a broken air dam wire and module. Huh? That's not what my code reader pulled. In any case they are replacing the fuel tank sensor and air dam parts under warranty, but I am getting annoyed with the dealer and/or the fact the truck keeps having things break. I've only had it a few months and it's got 13,000mi on it. I think the dealer service dept is incompetent. How does a fuel sensor break on a brand new tank or do they transfer the old sensor over from the old tank?
dealer called and told me the air dam was removed and the wire that connects to it had a piece of tape over it. I told them I bought the truck used from a reputable dealer. Previous owner must have removed the air dam, but have no idea why. They said it wouldn't be covered under warranty and it's $500 to add it back. I said no thanks.99% of the time the fuel tank sensor is just transferred to new tank
the old work order should state what they did
If they check your vehicle in using the pod. They will have a list of codes when you brought it in.dealer called and told me the air dam was removed and the wire that connects to it had a piece of tape over it. I told them I bought the truck used from a reputable dealer. Previous owner must have removed the air dam, but have no idea why. They said it wouldn't be covered under warranty and it's $500 to add it back. I said no thanks.
I would just solder the wires back together and put some heat shrink around it...I'm sure their $500 included a new air dam and wiring harness.dealer called and told me the air dam was removed and the wire that connects to it had a piece of tape over it. I told them I bought the truck used from a reputable dealer. Previous owner must have removed the air dam, but have no idea why. They said it wouldn't be covered under warranty and it's $500 to add it back. I said no thanks.
This just gets more comical with each visit to the dealer. Dropped off truck yesterday to get the fuel sending unit fixed. Naturally they couldn't fix it and had to keep it overnight. Was told it would be ready this morning. I call to get an update and they say they went to put gas in it and the pump is clicking off again which was the original reason in getting the new gas tank put in. They said they have their 45 yr service tech looking into it and offered a rental. I told them forget it. I want my truck today and I'll go to a different dealer to get this fixed. Unreal. This should have been a simple fix. So while the gas gauge now supposedly works, the original pump click problem is present.This must be either the worst dealer or I just have bad luck. After the fuel tank was replaced, the gas gauge no longer worked. I made the appointment to get it fixed for today. Last week the check engine light comes on. I pulled a P4056 code which is typically an Evap small leak code which I assumed was related to them changing the tank. I drop truck off today and they call and tell me the fuel sensor is bad and needs to be replaced and the engine light is related to a broken air dam wire and module. Huh? That's not what my code reader pulled. In any case they are replacing the fuel tank sensor and air dam parts under warranty, but I am getting annoyed with the dealer and/or the fact the truck keeps having things break. I've only had it a few months and it's got 13,000mi on it. I think the dealer service dept is incompetent. How does a fuel sensor break on a brand new tank or do they transfer the old sensor over from the old tank?
The costco nozzles are the worst. I have to hold the handle or it cuts out. Normal nozzles at other stations are fine.We now have "California" nozzles at costco in Georgia. They are more finicky than normal nozzles. I've never had a problem with my 33 gal tank.
When they replaced my tank and filler neck there was a new fuel pump as part of the new tank so maybe yours could have been defective out of the box. My dealer also said there is a sensor inside that assembly that if not working properly causes the tank to trip the gas nozzle when being filled. I asked if they can fix that sensor if it fails and they said no its part of the fuel pump/sending unit assembly.This just gets more comical with each visit to the dealer. Dropped off truck yesterday to get the fuel sending unit fixed. Naturally they couldn't fix it and had to keep it overnight. Was told it would be ready this morning. I call to get an update and they say they went to put gas in it and the pump is clicking off again which was the original reason in getting the new gas tank put in. They said they have their 45 yr service tech looking into it and offered a rental. I told them forget it. I want my truck today and I'll go to a different dealer to get this fixed. Unreal. This should have been a simple fix. So while the gas gauge now supposedly works, the original pump click problem is present.
Lol, now they just called and said the problem is a bad fuel pump and it's not driveable. No kidding! I told them that assuming you transferred over the functional pump from the old tank, how do you explain it's not functional in the new tank? They say new tank requires new pump, but new pump is supposedly defective. Huh? It drove fine for last week except fuel gauge not working, so I'm to believe the pump just suddenly went bad. They say new pump and sending unit is all one unit and corporate knows there are defective pumps being sent out but they don't know which ones are defective till installed.
Almost 2 weeks now and truck still not done. Called last week and they said part would be in, then nothing. Last Friday they said part will be in this Monday. Still nothing as of today. This is ridiculous. Are fuel pumps hard to get right now as they never said they were in short supply. I'm getting ticked off and patience is wearing thin. I've got a ceramic coat appt next week and I'm not rescheduling again with the guy.Going on a week now waiting for them to find a functional fuel pump. I thought the pump issues and recall were for the diseals?
Yes they are on backorder depending on what pump you have.Almost 2 weeks now and truck still not done. Called last week and they said part would be in, then nothing. Last Friday they said part will be in this Monday. Still nothing as of today. This is ridiculous. Are fuel pumps hard to get right now as they never said they were in short supply. I'm getting ticked off and patience is wearing thin. I've got a ceramic coat appt next week and I'm not rescheduling again with the guy.
Got truck today. Now another check engine light and P0154 code comes up. Can't believe they returned the truck to me after all this with a cel. I drove away and pulled the code when I got home. I figured it'll go off and had something to do when they put the new fuel pump in, but interestingly my truck won't go into Eco mode now. If it's truly a lean condition as noted by the code definition, would this prevent eco mode from working?Yes they are on backorder depending on what pump you have.
