Gman
FIFYNAV maps will NEVER updateon an OTA.
I notice that the EQ version updated. Anybody hearing anything different?
Didn't know it was brokenFIFY
The voice navigation now works.
FIFY
As in find Home Depot and it lists everything near meMeaning you can hit the voice button and give it an address?
Update....I was in my truck today and when I first started it my split screen went to default. Required me to pick what I wanted displayed. When I shut it off, there was some over the air notification notice but I was in the process off opening the door at the time I looked. So it went away. Coming home, same thing screen was in default and I got the notification to do the update now or later. Pushed the "now". The truck was in the garage at the time. Then, hopped in the truck to get curbside carryout. Screen was default again and after about 10 minutes, I got a notification indicating the update failed and an option to call. I wasn't about to start that with dinner in the truck. So I'll see what pops up tomorrow.
Dumb question.... I went into setting and for the life of me, I can't find your pictured page/locationWell there we go. Haven't checked anything else out yet.
Press and hold your 2 outside icons on the bottom tray of your Uconnect screen for about 7 seconds it should go into dealer modeDumb question.... I went into setting and for the life of me, I can't find your pictured page/location
All of my voice prompts using Android Auto were all at volume zero after the update (even the google response beep after saying "okay google"). When you hear the left front speaker cut out, turn up the volume and that should take care of your issue. I had to do it for the google prompts and for Waze audio alerts/nav guidance.The only change I've noticed thus far is that Google Maps is now silent when using CarPlay. I will need to do some further testing to ensure this change isn't due to the recent firmware update to my CARPLAY2air device, since both were updated at the same time. I will also need to test to see if audio for other apps is still working via CarPlay.
I've not noticed audio changes. I also haven't tested the voice navigation yet with the factory nav, but I'm interested in doing so.
