Whiskey_tango
- Jan 6, 2019
My experience was similar to KSN but I had to twist both sides a little to get the bottom bolt in. It sounds like you have the UCA's in the right orientation, the small hole in the tube faces the rear. Check your front drive shaft it sounds like the out side joint has slipped out and was binding up creating a block. Before you start raising the lower control arm make sure you can freely turn the hub by hand and the half shaft turns smoothly. If it binds up what happened is when you pushed lower control arm down and the spindle is flopped over to the outside of the truck to make room you over extended and slipped the joint on the CV not a big deal, just gotta make sure its back in the right place before you start raising the lower control arm. this happened to me on the Ram, and on my GMC when I put the level kit on it.
You might be on to something there. I couldn't twist the knuckle and I think I recall the rotor being locked up as well.
Thanks
