Mine lines up just like yours on the three tabs (slight gap), yet there appears not to be any adjustment (it's designed to line up as such). What are your thoughts? I saw other folks post pics with theirs lined up flush.Ordered through my local dealer, had it in a day. No shipping and used the 15% off Mopar Coupon. Looks great, sounds good, and I can feel a little more responsiveness. And its from Ram so no need to worry about warranty or something breaking from it... I'm happy, end of day thats all that matters guys. Be safe out there.View attachment 80101View attachment 80102
Mine is that same way. It seems to prevent the lid from mounting up flush (like the pictures). Does yours also have a slight gap when installed?Also notice a tab was missing in the middle where the top wedges down from. Doesn't look like it was broken, just left off. Anybody else's this way?
Tried that too (but with plastic trim tools) however, the middle tab on my kit seems to be intentionally missing. Its as if it was redesigned this way for some reason.Mine looked the same way. Took a table knife and put it under edge and lifted it slightly. Pulled cowl towards front and it slid right in flush. Seems to be a warping issue with front section.
Very flush! Did you have three tabs in the middle or was the middle one missing?Mine is pretty flush.View attachment 85985View attachment 85986
Perhaps i need to work it over the lip a bit. Did you have to play with it some to get it flush?I do have the 3 tabs.View attachment 85989
Wow, is your truck and car really that close or is it a angle illusion?So excited. Hugeeeeee box though
Update: got it... finally!!!I had mine installed by my dealership. But it does fit flush so I would think yours just needs to be tweaked a little.
What did you have to do cause mine was installed by dealer now I’m going to have to adjust it...Update: got it... finally!!!
I unhooked the three tabs by lifting up the rear lid. Then, standing in front of the truck’s grille, I pulled the top cover toward myself and used a plastic trim tool to pry the top cover over the lip. Took some elbow grease but finally got it right.What did you have to do cause mine was installed by dealer now I’m going to have to adjust it...
