The curiosity side of me decided to look into this more. I am going to send oil samples from my last oil change that I kept and oil from when I just changed from the Amsoil EA15k50 filter to the Wix filter sent to me as a replacement. I am also going to do my own testing for solids in the Mobil 1 Extended filter I used and the Amsoil filter I just took out.
So I've opened up both filters using a standard kitchen can opener. I had to use a small chisel to complete the removal of the tops. The filter media pleats are just cut out with a razor knife. The first observations were that Mobil 1 Extened and the Amsoil filter housings are definitely made by the same manufacturer. There is probably only a handful of manufacturers for oil filter housings. Mobil and Amsoil probably just specify the filtering media and each has there Logo put on the housing. The reason I bring this up is every part of the housing is identical, including the bypass valves.
View attachment 91325View attachment 91326View attachment 91327
I checked the bypass, and there wasn't anything on the seat that would be allowing continuous leakage and the spring rate felt the same in both filter housings. So I think problem had to be a plugged filter element.
The pleated elements are very different, the Mobil 1 is a thin paper filter, the Amsoil is a fabric bonded to a screen and was thicker, similar to a K&N air filter element. I didn't observe any large carbon particles, but I noticed more metal in the Mobile 1 filter, but that was only the second oil change and had over 8.5k miles compared to the 3.4k miles on the Amsoil filter.
At Blackstone Labs, they can analyze the filter elements but I don't want to spend $75ea plus the $30ea for oil analysis. I worked in the oil refining industry for 40+ years and have lab experience testing different crude cuts for solids, so I will make up my own test, even though it won't meet ASTM standards. I want to compare the solids content and compare the filters. This along with the Insolubles from the oil test will hopefully give some insight on % total solids in oil and filter.
I'm not sure anyone is interested in this, but as I said, I am, especially since I spent my whole career in R&D.
