Rammit
[/QUOTE]I just got my tuff country 2" leveling kit in. I went ahead with the fuel rims, going to do the level tomorrow. I had 295/65 ridge grapplers on my last ram with level kit, but I am considering 295/60. same offset, but not sure if I will get the same clearance as you since your lift is 3.5" You got any suggestions?
65, member: 1183"]Here’s mine.
My last truck ran 295/60/20 on stock rims and had just a little rubbing. This truck does not have the full 3.5” lift as I did not install the pre-load spacer. I have a thread detailing why if you want to look up. I think your truck will be fine with the 295/60. As long as your offset isn’t too aggressive (wouldn’t go much from stock) you should be fine. Hope that helps
