Yep. Me too. Bought the 2019 Ram 1500 Rebel Crew Cab end of June. First time owning a pickup. Initially thought something wrong with the front-end drive. But anytime I asked anyone who rode in the truck with me if they think that's normal would ask what? Figured truck needs to be broken-in. Then figured it might be the big deep-treaded tires (which the dealer had inflated to 64psi!!!). Of course lowered pressures to 55 front 45 rear as per the door label. Now have close to 3000 miles / 4500Km. Been watching this threat since October. Got an ANC delete cable. This actually helped (especially since I was hearing clipping from the passenger-side speaker when playing 80s music (sorry - I kinda like 80s music)! Anyway the ANC deletor took care of the speaker problem, deep weird grinding noises have all but gone away (still some intermittent vibes felt on the steering wheel - but it doesn't really bother me). Unfortunately, the oscillating hum while coasting (roughly 1200-2000 RPM) or with engine breaking at 30-40ish mph is still there. Not as loud pre-deletor, but still there. I don't have much time in my schedule to be taking the truck in for 'service,' especially based on many of the comments that confirmed what I already know: Unless something is seriously broken, you take it in, they check it out, tell you there is nothing wrong and if the problem comes back to make another appointment. That's partly why I bought a new truck - to avoid time servicing my old Durango. Moreover, was happy to see there's an ANC software update - and folks initially said the problem is solved! But many have further complained, even with the latest version of the software the oscillating hum is still there. Personal experience: noise similar to this indicated a ball-joint (on my wife's Journey) or rear differential losing oil (on my old '05 Durango). It isn't the wheels or differential(s). Honestly, I think Dodge created a substandard 8-speed tranny, or the forward drive mechanism, maybe went ooops! or maybe knew about it after prototype but either way they were either too late (was already in production) or were pushed to production due to corporate deadlines, and thus tried to fix the issue by using active noise cancellation (the ANC module). Trouble with ANC is that it has to emit cancellation waves specific to the noise received through the mics but without cancelling-out music or people talking (which actually would be cool to see - people talking but no one can hear them). I think the humming is within the bandwidth of voice and music - it would therefore be impossible to fully cancel (and would as a biproduct produce weird vibrations and noises whenever the cancellation goes out of phase to the noise the mod is trying to cancel). Now unless there's a software update for the drivetrain itself - or unless Dodge actually says: here is the problem, here is the fix! I think putting up with it for a year or two, maybe by pumping up the stereo (going deaf in the process), and then trading the truck in might be the best solution. PS: got into a small fender-bender, nothing major, and got a Silverado rental. I hated it for lack of features. But let me tell you, it was very quiet and smooth in comparison. Anyways - I know I'll get a reply saying something like:
"I do apologize that you are also experiencing this concern. To clarify, have you had a chance to address this with your selling dealer? If not, I kindly recommend doing so as they are in the best position to provide assistance on this concern. Additionally, please know that our team here is more than happy to provide you with an additional layer of support for that process. We are just a PM away."
Sorry CS folks - at least you're getting paid to respond to these. Maybe I'll take it to the dealer during the Spring or Summer months. Maybe there'll be an actual solution by then. But I don't have time to do the back-and-forth dance right now. Too bad cars and trucks don't come with money-back warranties, otherwise this would have been a return and request for refund within three weeks of purchase.
Follow-up:
Had nothing better to do tonight other than work on several projects - slow night. Anyways, this is the type of noise one typically hears (usually only) when driving/coasting a car on a low gear - if you set your trans on first for example (most vehicles), you hear a decidedly humming sound as the vehicle moves faster, especially beyond the shift point to second. I decided to take the truck out for a spin and here is what I did and what I found - if this helps:
-Outside conditions (wet/foggy - roughly 50 degrees F / 10 C); Trans Temp 80s to 90 degrees C)
-Fan and stereo off (PS: do both and definitely hear the oscillating hum)
-Accelerated to 60 mph and then decelerated. Humming persists, loudest around 40-30 mph decelerating.
-Pressed on gear limit across all 8 gears - accelerated to 8th gear then decelerated to 1 (except for reverse) the humming is there on each (just different pitches - as the transmission lowers the gear while decelerating the higher the pitch; high-pitch especially on 3, 2 and 1, lower humming (and more annoying pitch between 4th and 6th). Deep muffler/exhaust sound (which I love) may contribute to not hearing as much of an annoying sound on 7th and 8th.
-Sound is not there on reverse.
-Ran on 2WD, 4WD high and 4WD low (latter at speeds below 20mph) - no difference.
-Ran the truck on Tow/haul (up to 50mph). While the higher exhaust and engine noise rev-ing overpowers the humming noise, listening carefully, you still hear the oscillating humming noise across all transmission gears as the vehicle decelerates (honestly, I think the noise is there on acceleration, the engine rev-ing and exhaust sound overpower the humming for our ears making it seem like the noise is only there on deceleration or coasting).
-Ran with trac-control off - no difference.
-Ran with rear-axel lock at straight line to about 15 mph (don't drive w/ra-off except for slippery surfaces unless straight-line) - no difference.
-Remember - this is all with an ANC deletor installed so ANC plays no part in this.
-I think the problem is with the design of the drives (both front and rear), not the transmission. I'm not a mechanic or engineer though (I mean it could be some bearing somewhere or these days some software upgrade needed for the drivetrain). Understand when dealership mechanics don't know. There's nothing that indicates the truck has any mechanical problem (e.g. excessive friction in the transmission = greater heat, but it is perfectly normal according to the instrument panel).
Anyway,
Good luck to you'all. Let me know if ever there is a fix.
