Installed Dual Battery with Redarc Isolator
I got to say this is very interesting and great job on putting all of this together seriously but I have a question why do it this way instead of hard wiring, taping, or going into internal/external power distribution centers?
whats the part # for the battery shield/cover? great write up btw
Here is the parts list:
REDARC Smart Start Battery Isolator & Wiring Kit 12VPart # SBI12KIT
Bolt-Hex Flange HeadPart # CH6104378AA
Bracket - BatteryPart # CH68082538AB
Insulated Battery ShieldPart # CH56029822AD
Battery TrayPart # CH68350658AC
12V 750AMP Flooded BatteryPart# CHBBH7F001AA
You can still add a distribution center to either battery. The reason for doing this was to take the load off the primary battery, for accessories such as dashcams, refrigerator coolers, and other accessories that you might need to power while the engine is off and do not want to drain the starter battery.
Im also thinking about doing a dual battery setup. I've done it on several other vehicles. Check out Blue Sea Systems 7622 ACR. It's bulletproof and marine grade.
What is the life range for the battery
Has anyone done this dual battery setup on a 5.7 etorque?. Is the etorque capable of charging the second battery?
So far still running the factory battery for the starter battery with just over 70,000 miles on the truck.
Looks like this setup is stable and helps balance the amperage load between the batteries when in operation. ⚡ (y)
Can this be done to the Ram 1500 etorque models?
The battery isolator connects directly to the main start battery and the second battery...there are no connections elsewhere. I suggest you go to the Redarc web site...and send/ask your question...their isolator is designed and built in Australia, (they have distributors worldwide...USA), they will be able to tell you if there are any electrical restrictions using their isolator...FYI RAM trucks are sold in Australia, so they should be able to give you accurate info with regards to the e-torque model.
Got the battery tray & Battery installed this weekend.
After some serious thought and no other options, I decided to modify / fabricate the Mopar 2500 Passenger Side (Right) Battery Tray - Mopar (68350658AC).
The first thing that I had to do was cut off the bottom hangers from the battery tray since they did not have a place to mount to the frame and they were in the way for setting the tray on the wheel well liner.
The next step was to sit the tray down in the wheel well and see how it lined up.
After sitting the tray down in the wheel well. I had several more challenges:
  1. The wheel well holes did not line up with the holes in the bottom of the battery tray.
  2. The front bottom of the battery tray did not touch the bottom of the wheel well.
  3. The hood shock is hitting the lip of the top battery bracket.
So back to the work bench for another round of cutting and some fabrications.
Cut the top hanger from the battery tray. (I had to add a T-Strap)
The next step was to add a heel to the front bottom part of the tray so that it would sit on the wheel well and allow me to drill a hole for the wheel well screw.
I had a 3/4 in. Schedule 40 PVC Type-T Conduit Body on the shelf left over from a wiring project and it happen to be the perfect size.
Mixed up some J-B Weld and the next day it was ready to go.
I also should mention that I had to cut off the wheel well factory towers that lined up with the 2500 so that the battery tray would sit flat on the back part of the wheel well.
Since I lost the top battery bracket I had to fabricate a T-Strap to work to hold the top part of the battery tray. Lined it up with the factory hole on the frame. drilled a hole in the tray for the bottom of the T-Strap and bolted it on.
Used a 6 in. x 5 in. 14-Gauge Galvanized T Strap
I had to drill two holes for the front brackets to the frame. Used the factory bolts that I took from the air filter tray.
The factory bolts are: M8. 1.0
I used a Drill Bit: 1/4”
Then used a Tap thread bolt M8. 1.0
Nice work, and a great write up!
Excellent write-up. Followed everything you did and now have a second battery under my hood. However my factory hardware was M8x1.25 and it was a 17/64 drill bit that I had to use to get the tap started.
Good Job!
I guess Mopar changed the size of the bolts after 2019..
Replaced Batteries with a set of Super Start Platinum AGM Top Post Battery Group Size 94R H7 - 94RPLT from O'Reilly Auto Parts.
The truck is a 2019 model and still had the original lead-acid starter battery from the factory. I was noticing that the battery was getting weak and decided it was time to replace before it failed.
I went ahead and bought two since I was switching to an AGM battery which has a lower internal resistance and better voltage output then the lead-acid batteries.
