Got the battery tray & Battery installed this weekend.
After some serious thought and no other options, I decided to modify / fabricate the Mopar 2500 Passenger Side (Right) Battery Tray - Mopar (68350658AC).
The first thing that I had to do was cut off the bottom hangers from the battery tray since they did not have a place to mount to the frame and they were in the way for setting the tray on the wheel well liner.
The next step was to sit the tray down in the wheel well and see how it lined up.
After sitting the tray down in the wheel well. I had several more challenges:
- The wheel well holes did not line up with the holes in the bottom of the battery tray.
- The front bottom of the battery tray did not touch the bottom of the wheel well.
- The hood shock is hitting the lip of the top battery bracket.
So back to the work bench for another round of cutting and some fabrications.
Cut the top hanger from the battery tray. (I had to add a T-Strap)
The next step was to add a heel to the front bottom part of the tray so that it would sit on the wheel well and allow me to drill a hole for the wheel well screw.
I had a 3/4 in. Schedule 40 PVC Type-T Conduit Body on the shelf left over from a wiring project and it happen to be the perfect size.
Mixed up some J-B Weld and the next day it was ready to go.
I also should mention that I had to cut off the wheel well factory towers that lined up with the 2500 so that the battery tray would sit flat on the back part of the wheel well.
Since I lost the top battery bracket I had to fabricate a T-Strap to work to hold the top part of the battery tray. Lined it up with the factory hole on the frame. drilled a hole in the tray for the bottom of the T-Strap and bolted it on.
Used a 6 in. x 5 in. 14-Gauge Galvanized T Strap
I had to drill two holes for the front brackets to the frame. Used the factory bolts that I took from the air filter tray.
The factory bolts are: M8. 1.0
I used a Drill Bit: 1/4”
Then used a Tap thread bolt M8. 1.0
