If you've had the rear window leak...
Sorry, didn't mean to twist your panties. I just wanted to make sure that other members know this is not a recall to possibly save them from embarrassment or wasting their time at the dealership. You won't find the word "recall" anywhere in that TSB. And since I didn't receive said email, I have no way of knowing what was in the subject line. I was simply stating fact. Your post indicated it was a recall. There is a difference between a TSB and a recall.
For anyone else that is wondering, you can easily find out if your VIN is included in the warranty extension by visiting the ramtrucks.com website and logging in to your account (or creating one if you don't already have an account). There is a section where you can check to see if any warranty extensions apply to your vehicle.
No panty twist or irritation on my part just wanted to pass along what Stellantis called it.
Recalls are for safety related issues not parts defects that do not affect safety.
Update for mine: Dealer needed the truck for an entire day to make the warranty claim, since apparently Ram will ask for random pictures. Warranty approved with no issues, and they actually have the part in stock, so it'll go in next Monday to get it replaced.
I’ve had mine replaced twice. First for cracked frame at 3 years and 35k miles, second for slide window seal leak at 57k miles and just under 2 years after first replacement. Not happy at all with quality of this part.
They released a new part, in June or July, last year. So you don't feel quite as bad, GM used the same supplier, and has the same issue. You probably won't feel better, but at least we're not alone.
Took them about 3 hours to replace it, said don't wash it directly on the window or slam the doors for 24 hours. It's supposed to rain like 4 inches over the next two days, so maybe I'll try to cram it into the garage and make my wife's car sit in the rain.
:LOL:
I’ve already got a case # with Ramcare and I’m pushing for a lifetime warranty on my truck for the rear glass assy. Just initiated it so working through the process. Ramcare rep I spoke with is advocating on my behalf as this is completely unacceptable. Hope that the higher ups approve.
Expose the Dealership here.
What is their name and location?
Up date to my leaky window . Dealer in Benton Harbor Michigan ( Brookfield dodge dealership ) . So as ya’ll are aware we had video and Pictures of it leaking after they installed the window and told us they couldn’t duplicate it . Yet we were adamant about it leaking to them and about further damages like the headline , carpet and the backseats that are heated and cooled . They told Dr. Glass third party now T to warranty their work . So we informed Chrysler of the situation and since we are back in Pittsburgh it has leaked now for a couple of months now and Chrysler is expediting the back window ( 1 May 2024 ) it’s on back order after taking it to a dealership here in Pittsburgh area and they also did a leak test and with in a matter of seconds it start leaking . We reached out to Brookfield Dealership in Michigan about their findings and requested our money back for the half *** job that was done . They stated 1 Mohpar wouldn’t honor the warranty if we got our money back and 2 told us they have pictures and video of their water test which we just requested a copy of . It’s leaked from basically day 1 when we got it back and ever since . Chrysler is covering the glass and now my wife and I are worried of the headliner and any thing else that could be damaged since it’s been a couple of months now that it’s been on going . Especially we just had heavy rains that flooded the Pittsburgh area and are calling for more rain over the next few days .
Yes, it sucks when the headliner, carpet, and seats get soaked and possibly stained. But the bigger thing to worry about is the electronics mounted to the back wall of the cab, unprotected from water. Specifically the RF hub. When that goes it's more than an inconvenience, eyesore, or unpleasant odor. It makes the truck basically a giant brick. Completely unusable. And not to mention, at least in my case, the three month wait for the new RF hub to come in. You might want to consider using a car cover until they're able to get the rear window replaced if you're expecting that much rain. Sure, it's inconvenient. But at least you'll still get to use the truck. Just a little advice from someone who has gone through that.
A few months ago I noticed my rear window had a small crack in the frame and there were a couple water drops inside the cab. I went through my insurance company and had the entire window replaced by SafeLite Auto Glass. This weekend I noticed my rear window is leaking BAD - a lot of water on the inside.
I'm going to replace the 3rd brake light gasket, but I'm assuming it's the new window since the leak went from a little to a lot. Thoughts?
Photo of wet interior attached.
My 19 Ram 1500 backlite is leaking water in from the passenger side corner along with the CHMSL. The water intrusion also cause the defroster tab to detach from the window. Spoke with my dealership and they said only the CHMSL is covered under the extended warranty for my VIN. Contacted Ram and they told me there was nothing they could do about it and could not explain why my VIN is not included in the extended warranty. This might be my last Ram…..
I am having the same problem. Makes no sense.
spray water on the potential problem areas to check.
I did that. Water came pouring inside when I sprayed the top left and top right of the back window.
I'm bringing the truck back to the shop on Monday so they can seal it (under warranty).
it seems the rear sliding window is poorly designed by the suppliers; this is a big issue across multiple brands. I had the same thing with my 2021 Silverado I had to have the back window completely replaced. I would rather just have a solid window to be honest about it. I never had a problem with those.
Well here is the latest , 29th April took it to the dealership here in Pittsburgh after work in the morning and got a call from the dealership after months dealing with the leaking back window . Told me they ordered the wrong part and willnt be in til 01 June .
Out of curiosity...Where are the RF hubs mounted in the Chevy, Ford & Toyota's?
I’ve been following this rear window leak thread since it started and some others as well and I figured my 2022 would have this window leak problem at some point towing 7k# enclosed car hauler 60% of the time. Yep, last week with 33k miles and 30 months old a small leak started that runs down the window on the passenger side tight up against the pillar. Noticed it right away and used a towel to keep it contained.
I’m not having my vehicle tied up to have this window replaced only to find out it leaks again like some others have had after replacement. It’s an inferior design / manufacture and installation. I get it and here’s what I did.
Went to Autozone and purchased 3 tubes ($25) of Permatex 81730 Windshield & Glass Sealant 1.5oz. It dries clear. Taped off the window with Frogtape that is superior to that blue painters tape. I left the CHMSL in place and taped it off. Started on passenger side, used the majority of one tube filling until level up to the sliding window. It flows nicely. Wiped it smooth and then immediately removed the tape before doing the drivers side. Did same and finished with the center window last. I used every last bit of sealant and could have used slightly more. I cleaned anything that got on the window front or paint with lighter fluid.
It looks perfect, and standing on the ground you can’t see it. Haven’t had it in the rain yet, but I’m assuming it’s fixed. For me traveling/ towing the upper Midwest roads that are some of the worst this is a better choice for permanent repair that only took 2 hrs.
That should do it.
Ram dealer needed photos of all over the truck to send to Stellantis. "To make sure we aren't gaming the system." Yes, because the dealer isn't jam packed with service and warranty work anyway...
Estimated 3+ month wait for the window.
I'll be accessing the RF hub so I can cover it with a plastic bag in the meantime.
Unfortunately I also have the driver fender leak. Mechanically this truck has been great. Assembly has been dog ****e. I have cars that are 40 and 50 years old that don't leak.
