I have a 2020 Laramie with 17k miles. Noticed the rear window leak after the rain last week. Ended up just doing the Permatex window sealant fix myself. No leaks so far.
GM has a problem with their sliding windows too they are very similar to rams in those years as I had to have mine in my old 21 Silverado changed do to leaking. I think those were just designed from the supplier terribly.
for this get some marine weather stripping from Lowe’s or Home Depot. Take the old gasket off, clean the surface well, and put the new weather stripping on, making sure the seam is on the bottom.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
