Oh, all you poor RAM owners should just buy a Ferd…
On second thought, maybe not: ”The Ford f150 sunroof recall is one of the most controversial recalls in automotive history. The issue itself is a relatively minor problem and an easy fix.
In the rest of this blog post, I will tell you all you need to know about this recall. Read on.
Does the Ford F150 have a Recall on the Sunroof?
The Ford F-150 is not immune to recalls. Ford has issued a recall for the sunroof on the Ford F-150. The recall was issued due to the possibility of a leak in the sunroof or even detaching from the Pickup.
The recall affects 2014 and 2017 models of F-150s equipped with single-pane panoramic sunroofs. The problem was discovered after some customers reported water leaks in their vehicles, while others say they detached from the pickup.” Portion of article quoted from F150advisor.com
and…
(Excerpt taken from f150gen14.com, post dated Sept 14, 2022):
“So like many people, my new 2021 developed a severe leak from the sunroof. I never left it open but it would regularly leak all over my seat and floor mat. The microphone on the roof essentially became a funnel for all the water build-up. I read multiple forums and everyone suggested cleaning the drain, well I ran a weedwhacker cord through almost the whole thing but still, no water would drain. After trying compressed air and a few more weedwhacker cord attempts I decided to tear it apart. I kind of went overboard and took too much apart but I did find an issue with the drain tube.
Near the exit point, the drain tube was pinched behind another part, it was difficult to see what exactly was compressing it but once I gave it a few tugs it freed up and a rush of water ran through the drain. Hopefully, this will be the end of the flooded interior!” (End of quoted portion)
Lest anyone think I am a blue oval hater, I owned a 2015 F150 with the 2.7. that’s an amazingly strong engine. I still have a 2014 Edge that’s been a really good car, unfortunately it has the 3.5 Duratech engine with the internal water pump, thats a $1700 repair at Ford, just for a water pump.
