vincentw56
- Aug 5, 2020
You can enable auto high beams. That only requires the DASM.Can I enable auto high beams or does this need the abs and hcu unites?
Awesome would I enable only one thing or multiple functions to get it working.You can enable auto high beams. That only requires the DASM.
It is listed in the PDF in the first post. I believe there are 2 settings. I think I'm AlfaODB you can just search for High.Awesome would I enable only one thing or multiple functions to get it working.
You can't use AlfaODB to calibrate it. Find another dealer or a windshield company that will do it.I wonder if I could go in and try to fix my ACC, FCW, AEB and such with alphaobd? The dealer couldn’t get my systems back working after they tried to calibrate the system after having my windshield replaced. My truck has an unlocked pcm and is tuned and they say that’s why it won’t calibrate which seems odd to me since it has worked just fine for 2 plus years tuned.
Yeah, if you read through the thread, which I know is huge now. We found that the ABS and HCU had to both be bought new, some tried just the ABS, but that didn't work. And one of the guys spent a lot of time doing the same as you and researched a ton going to different dealers.Just got back from the dealership. My truck is 1C6–SRFLT2NN–183510, a 2022 Rebel without ACC. They don't even have an HCU listed for my truck in their parts system, it shows up blank saying reference only. Sticker on my HCU says it's 68535468AB which doesn't come anywhere on google, various part sites, or the dealerships system. They did have my module listed as 68436461AJ. I had them run the vin on a 2022 Limited still on it's way to the dealer lot with ACC, couldn't find a Rebel with it. They pulled the same part numbers for module and HCU as on the write up, with the exception that a new module revision is out so it's 68436462AK now.
No idea what's going on with my particular HCU though, kinda odd that the part number doesn't exist. I was hoping the dealer could tell me what the system thinks it is. The printout they gave me shows the diagram with the module as 1 and the HCU as 2. Module is all populated like I'd expect it to be, description and part number. But the HCU is all greyed out and only has the description. I'm assuming I'd need to replace both to get ACC working, as I know my Module is the wrong part number I'd imagine the HCU is as well, but I'll have to guess instead of have a solid answer.
You are wasting You time going to dealer. If You want to know Your part number call: (214) 544-4505 and give them Your VIN.Just got back from the dealership. My truck is 1C6–SRFLT2NN–183510, a 2022 Rebel without ACC. They don't even have an HCU listed for my truck in their parts system, it shows up blank saying reference only. Sticker on my HCU says it's 68535468AB which doesn't come anywhere on google, various part sites, or the dealerships system. They did have my module listed as 68436461AJ. I had them run the vin on a 2022 Limited still on it's way to the dealer lot with ACC, couldn't find a Rebel with it. They pulled the same part numbers for module and HCU as on the write up, with the exception that a new module revision is out so it's 68436462AK now.
I only wanted to know what it was according to their system, since I couldn't find my HCU part number anywhere, but it just doesn't exist even in their system. She thinks it was a stand-in number that didn't go anywhere but wasn't sure, only that it doesn't show as being a part. Since I know my module part number is wrong, I'm guessing that the HCU is too and replacing both. I didn't see anyone else have that issue, so I brought it up just in case someone googling finds it helpful for some reason. Never know, I've been that guy that found a single sentence in a 15 year old thread useful. As far as running the 2022 vin, I just wanted to know if it was the same. Didn't seen anyone confirm what the 2022 had on it.You are wasting You time going to dealer. If You want to know Your part number call: (214) 544-4505 and give them Your VIN.
Page 4&5 in this thread about the same issueI only wanted to know what it was according to their system, since I couldn't find my HCU part number anywhere, but it just doesn't exist even in their system. She thinks it was a stand-in number that didn't go anywhere but wasn't sure, only that it doesn't show as being a part. Since I know my module part number is wrong, I'm guessing that the HCU is too and replacing both. I didn't see anyone else have that issue, so I brought it up just in case someone googling finds it helpful for some reason. Never know, I've been that guy that found a single sentence in a 15 year old thread useful. As far as running the 2022 vin, I just wanted to know if it was the same. Didn't seen anyone confirm what the 2022 had on it.
At any rate, I have the parts on their way, I'll post anything I run into doing the procedure.
Jimmy07, Thank You very much for Your continues support! I had some doubts, because description is a bit tricky. For 68456007AA description is matching, but on the picture different part is shown https://www.moparpartsinc.com/p/90881875/68456007AA.html 68312620AG for $468.60 seems to be a good deal. As I understood is only display and radio and NAV are in different module, just to make sure I will not miss my NAV after replacement.
Has anyone replaced their abs and hcu. I’m planning on doing this to add Acc. I would have it done by a professional.You can enable auto high beams. That only requires the DASM.
Several of us have done it.Has anyone replaced their abs and hcu. I’m planning on doing this to add Acc. I would have it done by a professional.
Yes, several of us have done this and got it working after going through all the steps that @tdb0021 put in the document. Some have tried to ask the dealer to install with no luck. I had a mechanic buddy of mine over and bought him some beers while he kinda supervised my bleeding of brakes and stuff. Wasn't nearly as hard as I thought it was gonna be, replacing the ABS Module and HCU were also pretty straightforward.Has anyone replaced their abs and hcu. I’m planning on doing this to add Acc. I would have it done by a professional.
It should brake. Mine does, saved myass from hitting pole on parking.
